Question about Gateway FPD2185W 21 in. LCD Television
No picture Dunno if I'm about to have the same capacitor problem that others had. Maybe you guys know... I went to power it up this morning and it gave me some problems: I leave my PC on at night, but I turn the monitor off. So this morning I hit the blue button: The monitor came on for a brief second and then off. You could see my desktop, but it quickly shut off. I run a PC on the DVI input and another PC on the VGA. I tried switching between the two and it didn't work. The monitor would come up for a split second, and then off. The power switch would eventually go to it's normal standby yellow. I tried unplugging the power cable for about 15 minutes - no help. So my last ditch effort: I unplugged EVERYTHING off the monitor - all cables, power, etc... Waited a few minutes and plugged the DVI back in first and then the power. It came back on. Am I looking at a permanent failure in the near future? Could it be these capacitors that was previously mentioned? I don't know if this thing is still under warranty. Probably not. Thanks, Homer
  • 159 Answers
Warranty, probably not ??? and gateway will try to sell you a new model !!
If it is warranted than it may cost a fortune with them to ship it back and forth !!??
You are probably haing capacitor failure starting and the low volatge is affecting the video card.
Even if you look at the capacitors and they are not bulging, it doesn't mean that they are not failing (some bad ones look like new)
I fix a lot of these.
ebays bammbammfran
Posted on Oct 09, 2008
How to repair a tv LG plasma 60pv250
Sounds like your Power supply is still good. but maybe the board for the video is bad.. (maybe the main board other than power supply. If you do a search on the internet for "60pv250" and "board". you can find replacement parts. If you are capable or know someone with some electronics skills you should be able to see if any parts on the existing boards are popped (sounds like a capacitor went) and then buy the right board
Feb 03, 2016 | LG Televison & Video
Standby/timer light stays on red. no picture or sound on tv.
this is a simple capacitor fix at your local tv guy..should be 100 to $150 max
Apr 09, 2014 | Sony KP-48S75 48" Rear Projection...
I have a samsung plasma hp-r4262 the picture went out, I have sound but no picture! The day it went out it made a pop noise, then no picture! What could it be?
The problem of your plasma tv could be on power supply. The popping sound you heard maybe cause by blown capacitor. Unplug the tv from the main AC outlet then remove the back cover of your unit. Try to observe if there's a bulge up or leaky capacitor. If you see this bulge capacitor replace it. Be sure to observe proper position because it has polarity. To replace this bad capacitor you should be needing following tools: soldering iron, soldering lead and desoldering pump. Be sure not to connect separated pins when soldering. Let me know what you observe upon replacing the bad capacitor. Good day.
Sep 03, 2011 | Samsung Televison & Video
TV LG Model 50PX1D-UC Flat Panel Television Loud Popping Noise. TV goes out. I turned on my tv the other morning and it let out a loud popping noise and the picture went out. Any suggestions...
The problem is that there is a bad capacitor inside the unit, it is either on the main panel or the power panel. The popping sound you got was due to the fact that the lead on the capacitor was bridging, therefore causing some electrical popping sound.
Run a check on the main panel and the power panel for any bad capacitor and replace it with a new one. That way, your television will be in good condition once again.
Take care and good luck
Jan 02, 2011 | LG 50PX1D 50 in. Plasma Television
No picture
May 03, 2008 | Gateway FPD2185W 21 in. LCD Television
Unidentifiable capacitor?
What i would suggest is taking those numbers going to your favorite search engine and entering them. Alot of times search engines can give data concerning hardware parts just by there manufacture number. This will give you a foundation to find what that particular part is and also maybe a replacement part. A word of caution about working with capacitors. Even after power has been off for several hours they can still hold a deadly charge. If you have a volt meter I would use it to test the part before even thinking about it. Capacitors are nothing to mess with unless you have proper knowlege on how to handle them and discharge them.
Sep 20, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
160 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
