Question about Xerox CopyCentre C128 Black and White Copier
My network controller don't work for xerox wc M35
When i turn on my copier  the network controller run up to 75 per cent and  it stop so it don't start,we cannot print anything.So my friend told me to clean all files on the hard disk or replace that HD by a new,i did the first  and I've the same problem if some one help me
  • 97 Answers
- Reinstall your printer then setup again.
- if not?
- Try reinstalling your O.S? backup first your data before you format your drive.
- After formating and setup O.S? install again your printer.
Let me know if the procedure is working?
Posted on Sep 22, 2008
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Xerox workcentre 5745 network controller boots to 75% then fails and the reboot message comes up.
Try the following:
1. Power down the device
2. AFTER it is COMPLETELY powered off (can take up to 2 minutes), unplug the power cord from the wall.
3. Wait 5 minutes with the machine unplugged.
4. AFTER 5 FULL minutes have expired, plug the machine back in and turn it back on.
If this fails to restore functionality please call for service.
Apr 03, 2014 | Xerox 5665 Copier
Hi, I have a Xerox Phaser 3100MFP/X copier. When I send a fax, the faxed copies have a 1cm thick mark all the way done the page. Please advise me on how to make this mark disappear or who to notify to...
There is a narrow glass window in the document feeder which the original passes. If there is even a small dirty spot on the glass it creates a line on the copy or sent fax. Try to clean the glass with alcohol (no whisky, hi) but 96 per cent spirit.
Aug 16, 2010 | Xerox Office Equipment & Supplies
Xerox workcentre 5030 network controller boots to 75% then fails and the reboot message comes up. How do you fix this?
If your system board does not work or network ram is bad then occurred this problem.
Jul 03, 2010 | Xerox 5665 Copier
Xerox 5252 running
You will need the contract. All Xerox machines made within the last few years unfortunately REQUIRE a XEROX authorized laptop computer in order to make any adjustments or to even get into the service mode. You can do the normal stuff and just pay by the call down the road when you need it but Xerox will charge you an arm and a leg for parts and labor.
If the machine is new, depending on your monthly volume you should expect to pay about 1 cent per page Black and 8 cents per page full color. Again these prices can vary based on your volume. The more pages you run the cheaper the cost per page.
Good Luck
Nov 20, 2009 | Office Equipment & Supplies
Xerox WC 7132 printer error code 016-601 error and error type illegal access detection
  1. Click on the "Configuration" tab
  2. Choose the account mode to "User"
  3. Click on "Detailed User Settings"
  4. Change the password details as per instructions from your printer administrator
cFor more help visit cbrtechsolutions
Sep 04, 2009 | Xerox WC7232 Printer
I have phaser 8400 with 40k page count. I am getting a mark on page about 6 inches from top of page and 1/2 inch from left margin. Sometimes it is a faint blur 1/4 inch wide and 1 inch long. Other times...
Run Remove Ink Smears from the Troubleshooting menu. Try running the jetfix snippet found on Xerox website under downloads. It sounds like you may have a defective printhead telling it to spit out some magenta ink at the wrong time.
Jul 05, 2009 | Xerox Phaser 8400 Laser Printer
Scanned image cannot be transferred via network to vista notebook
Usually a firewall issue. I set-up 10-20 Xerox scanners per week and Vista is almost always a problem. Check Windows Firewall, and any other software firewalls you may have. Generally, once you find the firewall and create an exception rule, it will work. I have found ATT and AOL firewalls that had to be discovered by checking the ADD Remove programs in control panel to find them.
Apr 30, 2009 | Xerox Office Equipment & Supplies
Xerox CopyCentre C128 Black and White Copier Logo
275 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
