Question about Kenmore Oasis HE 27082 Top Load Washer
Lid light on display washer inop
Where is the location of the lid switch on the kenmore oasis 27082
Had same problem, was only a loose connection on circuit board.
Posted on Oct 16, 2008
Kenmore elite washer troubleshooting
check the switch that recognizes the lid is closed...may need to open the top of the washer...Ron H
May 26, 2013 | Kenmore Oasis HE 27082 Top Load Washer
I have a washer mashine kenmore oasis top load wont start
check the lid safety switch located under the top thats actuated when the lid is closed if its bad the unit will fill but not operate on any cycles
Aug 02, 2011 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis HE model number: 110.27072603 washing machine shows LID error code. It wont work at all.... went half way through cycle... help.
Greetings,
this washer has a lid switch problem...or possible main board failure, but lid does concentrate on the lid safety switch. If you remember when you open the lid it stops..well, its a safety feature and prevents tub from spinning with lid open...this one is more difficult to service if your not use to working on washers...try unplugging machine and leaving off for awhile...does the door lock? check switch for lid fault
Nov 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Lid does not lock will not take cycle instructions
Kennmore Oasis washer; I just replaced the lid locking mechanism (8563937) with the upgrade (W10059230) from www.midwestapplianceparts.com
Jul 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
When you push start button error message says lid. Washer will not work.
Lid switch failure or out of adjustment, if your handy pop the top and adjust or replace the lid switch, or call your local authorized Kenmore servicer.
Good luck !
Jan 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I have a Kenmore Oasis HE 27082 and the lid lock bolt broke. How can I replace it?
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
You can access the lid switch at this point.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 22, 2009 | Kenmore Washing Machines
Oasis Elite Washer Lid does not lock
most likely lid switch/lock ..sensor is part of control bd haven't seen control bd indicate switch problem and it not being the switch
Jul 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Lid Display lit when starting wash cycle
LID code could mean that the door lid switch is not pressed. try to shut the door completely or the lid switch could have been broken. or the plastic that should press the lid switch could have been broken also. it is attached to the door i hope i was able to help.
Jun 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washer keeps reading Du
sounds like lid lock failure clips each side just below top eadge of washer about 3-4 insches from outside edge use stiff putty knife to push clips in and release top should be able to acess switch from there swtich will need replacing
Apr 29, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Error - LiD
Probably something wrong with the lid lock system. You should here a good sized click and the lid lock light should come on. If not, its probably a bad lock system. Good Luck!!!! Jim
Sep 03, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal De
fordexpert
 Brian Main
Brian Main
