Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
Ge pfs22 refrigerator
I bought a ge pfs22 less than one year ago. The temperature in the refrigerator rises to above 60 degrees on occasion. The technician replaced the circuit board, but the problem keeps coming back.
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
ginko
  • 19396 Answers
SOURCE: bottom freezer temperature rises as high as 35
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Posted on Jul 09, 2009
woodchuck789
  • 4070 Answers
SOURCE: variance in freezer compartment temperature
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the control board.
Posted on Sep 04, 2009
aasc
  • 1606 Answers
SOURCE: GE PROFILE REFRIGERATOR MOTHER BOARD PROBLEMS
Go into the diagnostic mode on your touch display .
1) . Press any button on the display 1 time except the temp adjust buttons.
2) Press the temp up and down on both the freezer AND refrig (all 4 at the same time)
3) when 0's show , release the buttons and press any button except for the temp adjust buttons .
4) NOW , fress the temp adjust buttons until the freezer side displays 0 and the refrig side displays 7 . 0 and 7 is for the thermistors test .
5) After 0 and 7 display , press any button again except temp adjust , and this will start the thermistor check .
6) You will have 7 thermistor tests , indicated on the refrig display , starting at 1 , then 2 then .......
7) The feezer display will tell for the corresponding thermistor , indicated by the refrig display , if the thermistor p = pass , s = short , b = bad (replace board)
After determining if or which thermistor is bad , then adjust the display to 1 on freezer display and 6 on the refrig display . This ends the testing procedure and resets the refrig back to normal .
Posted on Sep 26, 2009
  • 256 Answers
SOURCE: Hi my subzero 650 refrigerator temperature keeps
If your refrigerator has an electronic control board, this could be the problem (fresh food compartment control on the board). Or there may be a problem with the damper assembly that opens and closes allowing cold air from the freezer compartment (if available on your particular model). In either case, consult an appliance service company.
Posted on Feb 10, 2010
Temp is staying at 210 and does rise while in use. we replaced thethermostat and radiator cover. any ideas. I just bought it used 2 weeks ago
The I6 engine needs to be at 210 degrees, no less than that. The Temperature guage is just a guess, hook up a scanner and look at live data if you have one. Did you replace the coolant temperature sensor also? In 04', it's right above the thermostat you replaced. If you don't have a scanner----If the guage just rises a 1/16" of an inch to an 1/8" past 210, I wouldn't worry about it with your new thermostat in place.
Mar 12, 2015 | 2004 Chevrolet Chevrolet TrailBlazer EXT
I have a 1968 model GE refrigerator. A service technician told me there is a R12 freon leak in a length of copper pipe in back of the unit. He said this was caused by a valve installed in middle of th
Hi
if you mean the pipe is down by the compressor, this is how they normally do it since they normally do not come with service valves, but they should have removed the valve and soldered it closed. It probab;y only uses about 6 ounces, but it probably is R12. It can be converted to 134A but not sure if it cost effective. Also, when they added refrigerant years ago, did they repair the leak because you may have a couple issues
Dec 29, 2014 | GE Refrigerators
Kenmore 106 56703500 Freeze is cold refrigerator is not
The problem could be an intermittently defective temperature control.
May 16, 2014 | Refrigerators
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My GE Adora seams to be breaking down. Freezer is not freezing and temperature in both, Freezer and Refrigerator is dropping. HAVE reset the temperatures to GE's recommendation of 0 Degrees and 38...
One thing you can do is make sure condenser coils have plenty of area around them (nothing lying against refrigerator) to prevent air flow. If possible vacuum and clean condenser coils and make sure freezer door is completely closed.
Aug 01, 2017 | GE Adora (DSF25KGTBG) Side by Side...
My gas oven will not heat up above 300 degrees and
You may have 2 problems.
One. The temperature sensor could be bad. You can remove the temperature sensor and check it with a ohm meter. It should read 1050 to 1150 ohms. If not. It is bad.
Two. The glowbar ignitor could be bad and not igniting the gas safety valve.Open the bottom drawer of the oven and set the oven to bake. The burner should light in 60 seconds or less. Re-light should be about 30 seconds or less.
If it takes longer the ignitor is bad.
Dec 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
When the outside temperature is below 60 degrees my Bosch Boombox will not turn on. Once I take it indoors where the temperature is above 60 degrees, after a few minutes it will turn on and work fine for...
the issue your having was resolved with the newer units, im guessing yours was made before that. if you look on the bottom of the unit near the SN, it will tell you when it was made. If you purchased it less than a year ago, you may be able to get it replaced. 877-267-2499
Oct 04, 2009 | Bosch PB10-CD Radio/CD Boombox
GE PROFILE FREEZER PFS 22 SISBSS
hopefully you have a service warranty. I have had me fridge for two years and have replaced the temp control panel twice thus far. serviceman coming AGAIN on Tuesday because now everything in the fridge is freezing. cna't get the temperature in freezer and refrigerator regulated properly. GE knows they have a problem...something in the computer panel board sticks. I'd give anything to be able to put this on the curb and buy a new refrigerator.
Jul 19, 2008 | GE Profile PFS22 33" Artica French Door...
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
55 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
