Question about Sony VAIO PCV-RX370DS PC Desktop
My computer wont start, only beeps - Sony VAIO PCV-RX370DS PC Desktop
  • 1 more comment
  • Diskus Dec 19, 2008
    I conisder myself quite smart with computers but this one I can't solve. It conitnues with long beeps and a blank screen until it is shut off and the number of beeps indicates a RAM problem. Unfortianatly, the computer did not work when I tried different RAM. Now if i had custom built this computer then I would be able to fix it but it is for a school project that rebuilds computers and gives them out to those who dont have them. This means that all i had to work with were old computer parts that were already put to ether to form a computer. this means that all of these computers are haveing there own little issues. The others i can handle but this one just makes no sense to me. Help me if you can but if not thank you anyway because the chances of someone knowing what to do with this thing is pretty unlikely. By the way it is an emachines. P4
  • Anonymous Jan 06, 2009
    I found, on return from a week away that my flatmate's computer had been left switched on. The screen was no longer picking up signal as if it was in standby mode. Having tried to restore the screen there was nothing left to do but t turn the computer off at the computer itself by depressing the power button for a few seconds.
    Having returned to it a few days later and trying to boot it up, the screen still picks up nothing, and the computer whirs and ticks over with repeated beeping noise and nothing more.
    Again, it's an eMachines.
  • Diskus May 11, 2010
    Thanks for the posts on these you guys but this computer only has two ports for memory due to the fact that it is an emachines. But any more information would be of great use
On the motherboard that comes with this puter, the memory is in exact pairs...Ensure they are paired correctly...Hint, the pairs are not next to each other...Fill one slot, skip one then fill the 3rd...Fill the 2nd and 4th with another set if necessary...
Posted on Jan 04, 2009
  • 75 Answers
Check whether the RAM is inserted properly...unplug n plug it tightly
Posted on Sep 21, 2008
My computer is beeping and wont start
try checking the ram,check the fan is running,check hdd,
give all a good clean up.
Apr 27, 2014 | Gateway GM5472 PC Desktop
Computer starts to power up, two beeps then nothing and wont come on
severe virous you may need to format and reinstall all softwear.
Sep 18, 2012 | Gateway One Computers & Internet
My PC wont start up, all it does is beep constantly. I don't have any idea what to do. Please can you help?
Beeping when the computer first starts up indicates a hardware failure. It can be bad memory, bad motherboard or something else is bad.
You can look up the beep codes from your computer manufacturer's website under support or Google It.
If you are not able to replace memory or motherboard on your computer, You will need to have a computer tech look at your computer.
Sep 30, 2010 | Computers & Internet
Computer wont start.
I don't have access to your board details. However, beeps frequently represent memory problems. Try
removing the memory on your system and then putting it back.
You can access your memory on the bottom of your computer. It is likely the smallest rectangular hatch. After powering donwn the computer, remove one or two screws.
Remove the memory sticks by spreading the clips on each side of the memory. After removing them, put them back. This will clean the terminals and ensure a good connection. Before putting the back on, try to boot the computer. If you hear no beeps, all is good. Turn off the computer and put the hatch back on.
If you hear beeps, switch the memory modules. Try again. If you still hear beeps, try one module at a time in the primary memory slot. If one of these works, you should be able to buy a new memory module. Go to a sight like Crucial's and have it tell you what you can add. Perhaps this is a good excuse to upgrade.
You should do this at the kitchen table to avoid any static discharge.
May 20, 2010 | Fujitsu Siemens Lifebook N5010 Notebook
MY COMPUTER WONT TURN ON AND MAKING A BEEPING NOISE
beep noise indicates that the RAM is not detected.... TURN OFF computer....remove power supply....open the cabinet and remove the RAM.... clean it using a soft non-moist cloth...plug it back.... your computer will start... still if it is not starting, then the RAM might have gone faulty, try to check with other RAM.....
Apr 28, 2010 | Compaq CV 7500 17" CRT Monitor
MY ACER INSPIRE LAPTOP MAKE BEEPING SOUND WHILE BOOTING.
when i power on my laptop the acer logo screen is displayed on screen then the computer start beeping and the laptop get struck.i replaced the ram but the same problem arise.I removed the ram but the laptop wont startup and no beeping sound.When beeping start the laptop cooling fan get stopped.
Oct 27, 2009 | Acer Computers & Internet
Computer wont start and i get a series of four
4 beeps mean your th'ers something wrong with your computer's memory. Make sure that the chips are seated firmly in their sockets If that dont help pull out the chips and reseat the chips
Hope this helps.
Sep 28, 2009 | HP Compaq dc5700 Small Form Factor -...
Emachine wont start, just beeps
This is probably a problem with your DIMM(RAM) Did u recently install an extra RAM?If yes then remove it because the beep sound is due to the mismatch of frequency of two DIMM's. If not open your computer and check if the DIMM is loose just push it in and powerup your comp..Let me know if its fixed..
Oct 08, 2007 | E-Machines eMachines Desktop PC
Sony VAIO PCV-RX370DS PC Desktop Logo
151 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
