Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Cancel Light Flashing on Kitchen Aid Dishwasher
Have a Kitchen Aid dishwasher, model KUDR02FSSS3. The "Cancel" light continues to blink or the "Normal" and "Light China" lights flash back and forth. The other restets for the KUDI series do not work.
Any ideas?
Thanks We have the same problem with our Kitchenaid model KUDP02CR. The normal and cancel lights blink constantly. This happened after the circuit breaker was accidently tripped. We've tried cutting off power for a minute, 10 minutes and over an hour but nothing seems to be resetting the controls. Any suggestions would be appreciated.
  • sandkjohns Sep 22, 2008
    We tried this solution already with no positive results. The lights are flashing constantly rather than 7 times.
    We can't find any other info on how to reset it.
  • Anonymous Mar 17, 2014
    I have a Kitchen Aid Dishwasher, Model: KUDS30IXWH2
    The 4 Hour Delay and Cancel/Drain lights stay on all the time (but dimly).
    Can/How do I reset this?
    Thanks
    President:
  • 1,952 Answers
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Sep 21, 2008
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
try to figured out the switch
may be it stuck
or
try unscrew it tem
and then
try to check
the circuit board if it is
ok use the tester to locate
damaged!!!
Posted on Sep 22, 2008
  • 2,071 Answers
This a symptom of problem of control board panel, maybe there is a switch stick's or loose connection or cold solder in control panel board.Try to check all of these,so it will works normal again.
Click below for spare part's;
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Hope it may helps you;
Regards,
VOTIT
    Genius:
  • 1,550 Answers
It looks do be bad door switch issue, machine does not think door is closed so wont operate could also be a keypad issue not recognizing start button is being depressed.
    Genius:
  • 1,269 Answers
How about power off and unplug the power cable of the unit for about 2-3 hours to reset any static charge on the controls then power it back on. Check if that clears the blinking button.
    Brigadier General:
  • 5,158 Answers
Have you check to make sure one of the keys on the control panel is not stuck ? a replacement may be necessary.
Robert
  • Roberta Smith
    Roberta Smith Sep 22, 2008
    I've been unable to find a proper keyboard testing method that will help you determine if it has failed. I would suggest that if you cannot reset it thru most of the methods stated here already it most likely has or there is a serious issue that won't allow a reset.
    I will attempt to find the user/ service manauls later. do you happen to have the user manual handy ?. also i see two different models... are they both yours ?
    Robert
  • Roberta Smith
    NOTE 1. To invoke the Diagnostics Cycle,
    perform the following key presses in less than
    6 seconds while in standby:
    Heated Dry ➙ Normal ➙ Heated Dry ➙ Normal
    Alternative entry method if user interface is not
    functional: Unplug thermistor or OWI sensor
    2 times while user interface is unplugged (no IDs
    or keys present).
    ■ To rapid advance one interval at a time, press
    the Start/Resume key.
    ■ Invoking Service Diagnostics clears all status
    and last ran information from memory and
    restores defaults; It also forces the next cycle to
    be a sensor calibration cycle.
    Calibration cycles begin with a “sensor check”
    to determine whether the dishwasher has an
    OWI soil sensor or not. If the control detects an
    OWI, it forces two rinses to occur prior to Final
    Rinse (to assure clear water), then calibrates the
    OWI during the final rinse.
    I hate using cut and paste to provide a solution but typing this would have taken awhile.
    Please note if the keypad method does not work, there is an alternative method (shown). i will locate the thermister in the circuit diagram if you need it.
    Rake care
    Robert
  • 97 Answers
Have u chked for any reset button in dishwasher?
2 Suggested Answers
huuum
  • 750 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
Hi 1cassie1,
Did you try to turn the power off at the breaker box?
This resets the whole system usually!
Let me know how it goes? Write me back!
Other wise you need a hands on tech.
ngafm
please give me a rating before you sign off!
Posted on Sep 11, 2008
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwasher won't run. Normal light and cancel light flashing cont
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched.The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate. It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Thank you !!
Jun 18, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
May 17, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
1,223 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
