Question about Lexmark Office Equipment & Supplies
When printing the colour document comes out all diferent colours appear.
Not at all but some of which are used in the image
Posted on Sep 21, 2008
Printer only prints in black/white. have put new
It could be the print setting on your computer.
If you're using Windows, with your document open, go to File > Properties/Preferences. In the Print Setup tab, make sure to select "Print using all available ink" in the Ink Use section.
On Mac you can select Color in Print Setting in any expanded print dialog.
Sep 01, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I cant work out haw to change my printer from colour to black and white. please help. thank you.
This is normally done through the printer software. When you select to print a document etc, the print box comes up, go to 'Properties' and it may give you an option there to print in black only. Otherwise you may need to go to the advanced options where a 'Colour' tab should appear which will then give you that option again.
Jan 18, 2011 | Office Equipment & Supplies
I have a Lexmark 1200 printer. Colour promlems
It could be that the cartridge has become dry.
you have to try several head cleans using the printer software and if that doesnt help then the cartridge needs to be replaced.
Nov 03, 2009 | Lexmark Optra Color 1200 Led Printer
I'm out of blank ink. Can I print document with colored ink only? How?
If you want to print text & documents with a colour other than black then for MS Word and many other applications:
  1. Highlight the whole document by either pressing [Ctrl A] or use the mouse to highlight everything by right clicking 3 times rapidly or pressing the left mouse button down at the start of the document then scrolling to the end of the document while holding the button down and then releasing at the end of the document.
  2. Then go to the FORMAT tab and selecting FONT from the drop down list.
  3. Then select the colour you with to use from the FONT COLOUR box drop down list. Just be sure to choose a readable colour and not choose automatic or pure black.
  4. Once this is done you can print.
Note that images that use black will still print but will look strange without the pure black content but muckhof what appears to be black acually isn't and is a combination of the 3 / 5 or 6 other colours inthe printer so may print normally.
Sep 12, 2009 | Dell 942 All-In-One InkJet Printer
Canon MP360 not printing
You probably need a new purge assembly, it draws some ink to both clean and prime the printhead. When it stops working you won't get any ink to the paper.
Jul 19, 2009 | Canon SmartBase MP360 All-In-One InkJet...
How to print text using red or blue ink
I would just set the text color to red or blue in your document.
Depending on the program that you use it could have different steps.
Here is steps in Word:
You can change the Colour of your text by highlighting the text and then clicking on the 'A' symbol on the toolbar. This will change your text to the Colour which is underneath the symbol 'A' on the toolbar. To change the Colour, click on the arrow next to the symbol and select one of the colours from the small box which appears. This will change the Colour of your text as soon as you click on the Colour.
Another way of changing the Colour of your text is to go to 'Format' and then click on 'Font'. The font window should appear. Select a Colour from the 'Colour' section. You can see a preview of what the text will look like in the box below. You can also add various effects to your text by using the options in the 'Effects' section. This will also allow you to see a preview in the box at the bottom of the window.
Hope this helps. Please remember to rate this information.
May 03, 2009 | Office Equipment & Supplies
My printer is not printing the right color
chose print option, then chose properties. on the top you will get colour option chose it and chose print in colour option. and apply it. right now you can continouing with your colour printing.
regard
priyabrata (Be. in it)
Feb 16, 2009 | HP Deskjet 2460 InkJet Printer
Mono color
These models use a "3 colour" printing process. In other words, these printers do not contain black ink when the BC-05 colour cartridge is installed. To produce black print, a 3 colour printer mixes an equal amount of the three primary colours. This process is known as "composite" black.
As the ink in the cartridge runs out, one of the three primary colours will run out first, depending on the material that has been printed. After one of the three colours has depleted, this colour will be missing from the mixture required to print black, and the print will change colour. This is the indication that the cartridge needs to be replaced. Usually the remaining colours in the cartridge will run out soon afterwards.
Rate the solution as appropriate !
Feb 07, 2009 | Lexmark X7170 All-In-One InkJet Printer
Refilled ink cartridges problem colour
this is not a printer problem, you have a problem with colour cartridge! u can fix this in 2 diferent way: 1. replace the colour cartridge with new one, or gently clean the nozzle cartridge with a wet tissue until the cyan colour mark a line on the tissue just like the others colours: yellow and magenta. maybe must repeat this several times.
Sep 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
The HP laserJet Colour printer
I have reduced the size of the mega pixals on the digital camera before taking photo graphs this appears to have fixed most of the problem.
Apr 05, 2008 | Office Equipment & Supplies
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
