Question about Zanussi Washing Machines
I just bought a house and the previous occupants lost the zanussi guide for the washing machine. So I do not know the washinh settings.....e/g 40 degree wash etc...... as it is all in letters of the alphabet??
  • 706 Answers
Try this link to see if you can download a user manual http://www.zanussi.com/
If you can provide the specific model number..and cannot find it at this website.. let me know...
Hope this helps
Posted on Sep 21, 2008
How do you remove the lower front cabinet plinth on a Zanussi IZ 16 S washing machine?
Why? If I remember correctly behind the plinth do not have access to anything. If you need to replace the drain pump or filter housing you can access from the bottom or open housing of washing machine. This washing machine has a housing split into two halves and afterwards you will have access to almost all components of the washing machine.
If you need to replace just plinth, may help this spare part list.
Dado
Feb 19, 2017 | Zanussi Washing Machines
Re; my washer-dryer ZKH 7146 J, bought 2013. I wish to wash and dry Allergy Covers for bed linen mattress, pillow cases etc (100% cotton) which must not be washed or dried at more than 40 degrees. ...
I had to ask my doctor about that for my daughter and she told me to line dry. inside if possible because outside would only put pollen and other spores on it.
Sep 09, 2013 | Zanussi Washing Machines
I have a zanussi jet stream iz16s washing machine in a rented house we own. Then tentants rang me this morning to say when they put on a wash it stops once the wash is on and error comes up on it
Hi Amanda:
We will try to help with this problem, keeping in mind that many modern washing machines display error codes if they detect a fault. These error codes are meant for engineers and often they indicate just an area to check or implicate several possible parts. If the error code is relating to something like an out of balanced load or problems taking in water or a problem emptying water then the error code will be explained in the users or instructional guide.
We can understand that your Zanussi machine stops shortly after starting? If this is right, thermostats, heater elements, drain pumps, water inlet valves, programers and fan motors are the kind of things that can cause this problem. Having this fault put right is normally the cheapest option.
If this previous afirmation that we send it to you isn't right, try to note this error code or code number to send you additional details to solve it or parts replacement (if its necessary).
I hope this information provided initially, allows you to begin to diagnose the problem, if so, feel free to contact us again. Also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this previous answer.
Nov 22, 2011 | Zanussi Washing Machines
Have just bought a zANUSSI fjs 1225 W. Have run one cycle ( quick wash, 40 degrees, cotton) and the fabric conditioner was not drained away. Is this because it was a quick wash? V disappointed as I need a...
zANUSSI fjs 1225 W. Have run one cycle ( quick wash, 40 degrees, cotton) and the fabric conditioner was not drained away This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question. And don't forget to like us on facebook
Feb 15, 2011 | Zanussi FJS1225W Front Load Washer
My zanussi zwx1605w was washing then just stopped working.
zanussi zwx1605w. i have lost my manuel and cant washing machine to start?
Mar 26, 2010 | Zanussi ZWF1650W Front Load Washer
What is E 40 on Zanussi Turbodry 1200?
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board
Nov 24, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi zwf1631w error code e40
hiya
E40 is the fault code for the doorlock, these are relatively cheap and easy to fit and if an independent (non zanussi) engineer was to fit it, you will probably be looking at around £40-£50 all in as a rough guide.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Nov 10, 2008 | Zanussi ZWF1440 Front Load Washer
Washing cycles
if you put machine on a delicates or wool wash, it will stop still full of water giving you the choice to only drain or drain and spin
Sep 10, 2008 | Zanussi ZWF1440 Front Load Washer
Heating element
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
May 03, 2008 | Zanussi FC1200W Front Load Washer
Washing Machines Logo
87 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
