Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
Noise in crisper
A short rapid ratcheting noise comes from the crisper area of the fridge, sounds also like a quick bust of a machine gun, last 5 seconds
  • dwood71 Nov 10, 2008
    Same problem from the bottom SelecTemp drawer - seems to do it regardless of the setting. With door closed, happens every 10-15 minutes. With door open, happens immediately after changing SelecTemp settings.
There is a flap at the bottom back left of the refrigerator that opens and closes to let cold air into the area (much like the vents in your car). This flap is controlled by an electric motor to automatically open and close. The noise happens when the motor closes the flap; however, it continues to try to close the flap even after the flap is closed. There must be a ratchet on the motor and that is where you are getting the ratchet noise. I don't know why the electric motor continues to try to close the flap after it is closed. It could be a limit switch that has gone bad and the motor doesn't know the flap is closed. It appears that this electric motor/flap is a separate assembly in itself and I may just go order a new part to replace it. That is as far as I have been able to solve this problem.
Posted on Jan 10, 2009
Making loud noise like machine gun
Install a brand-new needle? Frequently, a damaged or bent needle will make a terrible noise.
Mar 20, 2016 | Brother PE770 Embroidery Machine w/ USB...
Bought 2003 Tribute V6 recently. Is it normal to hear loud vaccuum noise coming from pedal area when foot not on brake? Also, is it normal for fuel gauge too rapidly fluctuate, went down a quarter after 38...
No, none of this is normal. The load vacuum noise may be a busted diaphragm in the brake booster. The fluctuating fuel gauge is either a bad sending unit in the fuel tank or a bad fuel gauge.
Apr 04, 2011 | Mazda Tribute Cars & Trucks
My bike wont start. it just makes a noise like a machine gun
It sounds to me like your battery is bad. Take the battery to your local automotive parts house and ask them to load test it for you. What it sounds like is you have a cell shorting out in the battery. This would result in the voltage on the battery dropping below 12 volts when you attempt to start the bike. With the voltage that low, the solenoid "hold in coil" cannot hold in the solenoid plunger to engage the starter motor. The result is that "machine gun" noise you hear with the solenoid plunger going in and out rapidly.
May 09, 2010 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Freezer on the bootom type refridgerator
Hello. I am not aware of any recall. That said, you must repair these cracks to prevent mold and bacteria from taking over. Do this:
1. Go to any hardware store and get a couple of tubes of silicon caulk [white or clear] and a caulk gun.
2. Remove all of the food from the fridge and store it elsewhere for 3 days.
3. leave the fridge door opened and let it warm up to room temp. before you caulk the cracks.
4. Once warm, clean the area with soapy water, rinse and dry and then go over it with rubbing alcohol.
5. Caulk it and leave the door opened for 48 hours while the caulk cures and off-gases.
Mar 05, 2010 | Refrigerators
I am having big issues and the tech can't come out till next week. This morning my fridge was making a louder than normal sound. When I opened it up.....the crisper at the bottom was freezing my meat. The...
when did you last do a total manual defrost/clean vents and drain holes.if after, you still have problems call tech.this way is cheaper....also check door seal is touching frame all around
Feb 10, 2010 | GE Monogram® ZISS420DMSS Side by Side...
My ge fridge model # gss20iemcc is only keeping crisper area cool
If you changed the defroster. you know how to take the top apart. Take the fan cover off there is a lover on the cover should be factory set but sometimes they come loose and stop the air from going to the bottom. while you there look to see if it has ice in it. If it dose. the drain may be stopped up.
Sep 23, 2009 | GE Refrigerators
Whirlpool has water drip inside fridge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 25, 2008 | Frigidaire GLRT212ID Top Freezer...
GE Profile side by side
also ensure the condensor uder the fridge is clean of dust build up. high head preasure at the compresor discharge can also cause noises in the eveperator circulation. make shure you clear out this dust 4 times a year.
Aug 06, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Stainless Steel Profile refrigerator/freezer
It is more likely to be something getting caught in the fan. try pressing on the area at the back of the freezer behind the ice bucket and just below the auger motor housing . This is where the evap fan is and i have had cases of fan blades moving up the shaft a small amount but enough to just come into contact with the housing.
Jul 17, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
188 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
