Question about ASTVision 5B 15 in.CRT Conventional Monitor
I see two screens on my desktop.
I am seeing two screens side by side on my AST 15" CRT monitor.I am running win98 and when the computer boots up I see just the one Win98 start up screen. When I shut the computer down, I only see the one Windows 98 is shutting down screen.
How do I get just one screen on my desktop? I can not see the print on the two screens well enough to read it.
Thank you !
Lynn Smith
causey155@aol.com
  • 524 Answers
You are using a screen resolution that is not supported by your monitor. Start the computer in safe mode and open display properties. What ever resolution and color depth is (usually 640x480 and 16 colors), click OK button. Restart the computer. Go to display properties and increase the color depth to the maximum value. Set the resolution to 800x600. Restart the machine. Do you see double screens? No? Great! Now try increasing the resolution to the next level. (1024x768). When you click 'apply' you will be give 15 seconds to say it is OK. So if you see double screens, do not click anything. Display will revert to 800x600 resolution (and you will see only a single screen!)
Posted on Jul 30, 2009
Computer won't boot up
Does it sound like the computer booted up except the screen is black. Do you hear fans running, the hard drive spinning? Maybe the system booted up, but the screen has an issue.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 15, 2012 | Computers & Internet
Out of range
Boot through Safe Mode by pressing F8 once you start the system.
and select Safe Mode in the options to boot through it.
On the Desktop right click on the empty area of the desktop and select the properties, click on the Settings tab, on the screen resolution, move the pointer to the lower resolution, Press Apply and OK. Restart the system.
Sep 05, 2010 | Compaq MV 540 15" CRT Monitor
I have lg studioworks 552v monitor connected to a windows 98 computer . the screen had some problem before now rectified but i had 256 colour running now after repair there is only 16 colour . how to get...
In Win98, you will get only 16 colors if you don't install the VGA driver. It is not a problem with your Monitor. Install the VGA driver. If you can't find the driver (we may be able to help to find it), try replacing the VGA.
Apr 19, 2009 | LG Studioworks 552V 15" CRT Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Over rang
on crt monitor adjust screen referesh mde to 75Hz
or go to windows safe mod e
You can see your monitor ranges ;
right click desktop -> properties -> settings -> monitor
You'll see Screen refresh rate here
under the that there is a box "Hide modes that this monitor cannot display" click that.
Now computer shows your monitor range in list. When you select bigger value different than list , gives error " OUT OF RANGE "
Dec 03, 2007 | Proview PT 15.1" LCD Monitor
Crt screen power not appear
1)check the power supply
2)write in a desktop<properties<settings
3)setting<control pannel<display,appearance
Oct 13, 2007 | LG Studioworks 563N 15" CRT Monitor
LaCie 10 CRT
I would try booting the computer in safe mode (if it's windows) and adjust your display settings. It sounds as though it is trying to display from your computer something that it cannot properly.
Mar 28, 2007 | LaCie Electron IV 19" CRT Monitor
Color monitor
hi check 4 any magnetic induction near the screen (transformer ,speakers) and move it away windman
Feb 06, 2006 | ASTVision 7L 17 in.CRT Conventional...
ASTVision 5B 15 in.CRT Conventional Monitor Logo
53 people viewed this question
Top AST Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you an AST Computer and Internet Expert? Answer questions, earn points and help others
