Question about Honeywell Programmable Thermostat Heater
Honeywell RTH230B I am trying to install a Programmable 5-2 thermostat, but my current thermostat has six wires. Please advise
  • brittany1bra Sep 21, 2008
    I had a 6 wire honeywell, i bought the rth230b and have no idea where to put the wires. Can someone post a diagram?
  • Anonymous Nov 02, 2008
    I have the same problem. I have six wires and this thermostat only allows for five. What do I do with the Blue wire?????
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Posted on Nov 25, 2008
New instruction manual for RTH230B
Do you mean the Honeywell RTH230B programmable thermostat? Most of the Honeywell thermostat manuals are available here: http://yourhome.honeywell.com/en/faqs/thermostat . Scroll through the pages to find the RTH230B or use the search feature. The search engine found the installation and user guide in three different languages, see https://yourhome.honeywell.com/en/supportsearch#q=Rth230b . The direct link to the manual in English is https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf .
I hope this helps.
Dec 07, 2017 | Heating & Cooling
I have a Honeywell programable RTH230B. I changed
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jan 08, 2010 | Honeywell Focus 6300B 5-2 Days...
Six wire hook up and new thermostat has only 5
Some thermostats have an extra terminal for an outdoor sensor which tries to anticipate the need for heating or cooling. If this option is not present, you will have an unused terminal which may have a shorting link to a neighboring terminal. Your installation instructions should mention this if the option is or is not included with your model. Also, heat pump systems vary in the system control voltage and not all thermostats and systems are compatible with the more common split system thermostat.
Oct 01, 2009 | Honeywell Electronic Programmable...
Honeywell RTH230B will not call for heat.
On a call for heat an internal switch should connect Rh and W, if it does not the stat is bad. Try it with no wires connected.
May 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Model RTH230B uses a lot of batteries
THIS TYPE has been deemed defective! changeout to a different type.
Sep 04, 2008 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
I have my temp on C and I need to change back to F I have the RTH230B programable
May 30, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
Normally, you should have 5 color wires: W-White, Y-Yellow, G-Green, R-Red and C-Blue.
The Blue wire is a common from the transformer on older systems, which is probably hooked to RC terminal.
Try this: Remove the blue wire and jump the RC to RH with the red wire and you will be fine. Blue wire should not be needed with the new thermostat.
This should also be stated in the instruction manual.
Hope this helps.
Feb 03, 2008 | Honeywell Programmable Thermostat Heater
I can't program my thermstat
go to www.honeywell.com. There you will find a search tab. Type in the exact model number of your thermostat. You will be able to download the installation/owners manual.
Nov 29, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,362 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
