I'm trying to reinstall windows xp on my computer and I only have the orginal blue disk and the drivers disk. I cannot find the application disk.
  • Roberta Smith
    Roberta Smith May 11, 2010
    Was it a store bought computer or home built ?
    Robert
Well get to bios by pressing F8 of F2 then set first boot device to cd rom and then save settings. and continue by pressing enter.
u will surely able to reinstall it.
Posted on Sep 21, 2008
Application not found,txt IM invisible
I believed this isue occurs because the IM application was not properly installed or corrupted or either the operating system of your PC is corrupted as well, so i suggest to manually install again the IM application on your PC and if it doesn't work reformat your operating system by installing the orginal disk driver again (ex. Windows xp, vista, windows 7).
you can go to www.download .com to download IM apllication
May 28, 2011 | Computers & Internet
The application failed to initialize properly (0xc000007b). Click Ok to terminate the application." error message in windows xp sp2 for some application.kindly help me how to solve this problem...
your disk drive might not be getting continuos power
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Nov 25, 2010 | Microsoft Windows XP Professional With...
How can i install windows xp when screen showing blue screen
Check whether you have installed the SATA Hard Drive driver using a Floppy disk. Some Computers needs SATA Hard Drive Driver before installing the Windows XP. Try using Windows XP SP2 disk.
Jul 01, 2010 | Compaq Presario 700 470024-192 Notebook
How can I wipeout my laptop and reinstall windows
Reinstall windows is one to the wipe out process.
Once you have reinstall the windows all date stored is your laptop is lost. You need to delete the drive D during installing process. Wipe out is not totally cleaned your laptop reinstalling windows provide a new copy of operating.
Oct 03, 2009 | Dell Inspiron 6000 Notebook
BLUE SCREEN STOP ERROR AND NO HARD DRIVE SHOWING
Sorry, but there's no real way to troubleshoot this without actually having the device. The problem you describe could be anything from a simple corrupted system32 driver or MBR (master boot record), to a hardware failure. The simplest thing you could try is to boot from your OS installation CD/DVD, reinstall the OS, and re-install your applications. Next would be to re-format the boot drive and restore your data from your most recent backup. Sorry I don't have better news for you.
Aug 16, 2009 | Fujitsu Siemens LIFEBOOK S7010D...
C0000218 Registry File Failure on Fujitsu Laptop
Chances are when you reinstall Windows Xp you will lose your data.
You can recover your data by removing the hard drive from your laptop and plug it into an USB hard drive adapter and connect this to a working computer's USB port. This computer will see this as a external hard drive and you will see the various folders and files.
Copy and or burn your data folders and files to a CD.
Then put the hard drive back into your Fujitsu reinstall Windows XP.
Jul 12, 2009 | Fujitsu Computers & Internet
Dell Dimension 4700 - Driver Reset
1st you need to download or install all the drivers for your Dell computer. Try to use the drivers/utilities disks first. Once you can get online, go to Dell.com and look up your model 4700 and download all the missing drivers. Your Linksys Router is not a modem. The Linksys has the modem connected to it for wireless connections.
Jul 04, 2009 | Dell Dimension 4700 PC Desktop
After reinstalling my sound did not effect.
Re-Install the drivers from the system disk that came with your computer. If no disk, go to the website and download the drivers for your model computer.
May 30, 2009 | Compaq Audio card Sound Card
Laptop starts and after a while of using a blue error box falshes on the screen and turns off comp I can't even read the blue box its sooo quick!
That is called the BSOD (Blue Screen of Death).
try a chkdsk:
Chkdsk
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Type Chkdsk C: /R at the prompt.
Or try a XP repair:
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 24, 2009 | Sony VAIO VGN-T1XP/L Notebook
X1000 dl857a won't go into xp windows
do u have orginal xp cd u would hav eto boot into it redo the system foramtt it reinstall xp on it if u dont know how to do all this take it to get repaird or i can do it over night mail it back fresh copy wit xp drivers updates avtivated for 120 deliveryed back all latest cleaners on auto pro job
Jan 27, 2008 | Compaq Presario X1000 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
