Question about Brother 925D Serger
Lower looper i have broker the lower looper tip off at the eye and don't know how to remove it to install a new one. afraid to take the cover off i don't have a diagram of how or what is under there to make sure it gets back in the right place if it has to be removed. thanks
  • nsgus Dec 15, 2008
    same problem
My brother lock 925d serger sewing machines threads do not overlock sitch
Posted on Sep 27, 2008
I have a funlock 004D/004, the lower looped broke and I replaced it with one I ordered online. It makes a chain when I run it but when I try to sew fabric nothing catches. Any suggestions?
you have to make sure the looper is properly positioned. With the screw loosened slightly you should be able to move the looper up and down slightly, thus adjusting the timing. You are looking for the lower looper tip to come in slightly above the needle eyes, as close as possible without touching. Then the upper looper must come in right behind the lower looper "head" as close as possible without touching. The upper looper should then extend past the left needle by about 2-2.5mm, and the needles will come down before the eye of the upper looper returns to the right.
Dec 12, 2016 | Sewing Machines
Thread broke on bottom looper the first time out of box i had to try and thread and the tension was still tight The bottom threads were not stiching
I'm going to assume here you're talking about a serger. Unthread the lower looper and the eyes of the needle. Set the lower looper tension to 0. Rethread the lower looper, then the needle eyes. Then reset the lower looper tension (try about half a number lower) and see if it chains. If it won't chain, try replacing the needles.
Mar 17, 2014 | Janome Sewing Machines
Thread breaking at loupers on overlock machine singer
If it's the lower looper thread breaking, the cure is to unthread the eye of the needle(s), rethread the lower looper, then rethread the needles. Sergers have very specific internal crossings that are easiest to do if the various parts are threaded in a particular order. Typically, you thread the upper looper, then lower looper, then the needles. If you try to deviate from that without knowing exactly what you're doing, it tends not to work well.
In general, most serger troubles, especially for beginners, trace to minor misthreadings. It's easier, in my opinion, to rethread the entire machine from scratch than look for the minor error that's catching you up. And you learn the threading pattern well as a special bonus. <g>
If it's not cureable by rethreading a couple of times from scratch, the next thing to do is put in new needles, right way around, and rethread again.
Feb 08, 2014 | Singer Sewing Machines
Can't thread a consew 694ex
Typically a serger is threaded... upper looper(s) Lower looper(s) Needles from right to left. Anything else will cause you problems. If you break a thread... remove all other threads and begin again at the upper loopers.
Aug 23, 2012 | Sewing Machines
Serger - my needles break, never happenned before, and over travels on left upper looper
Make sure, Joe, that your needles are pushed up into needle bar shaft a's high a's they will go. Although same length, the left needle will appear higher than the one on right side when properly seated and tighten clamp screw securely. Check Lower Looper for proper threading--thread delivery eye of lower looper to far left "hidden" from sight. Use looper tweezers and it helps threading it. The thread then gets pulled to right side and goes front to back of that hole in front of you on lower looper. Follow threading guide on the cover door to right of your serger. Hope this helps. Jimmy
Apr 04, 2012 | Sewing Machines
Need instructions on threading 4-434 overlock serger
Open up the front cover. There should be a diagram right there, and you want to thread your serger step-by-step per the color-coded diagram so that the needle is in time with the movement of the loopers. If you randomly go about threading it instead of in sequence, the threads will collide and you will create a jam. The usual threading order: Upper Looper, Lower Looper, Left Needle, then Right Needle. Do you have long serger tweezers? Do you have a Looper Threader? If not, these are great tools to assist you as the Lower Looper is threaded right to left- an eye all the way to the far left, so it helps to have the tweezers and Looper Threader to maneuver in this very tight area. Many new serger users don't realize that other eye is "hiding" and miss threading it! Hopefully, you have a manual with additional pictures to help guide you. If you need a manual, try allsewingparts.com and perhaps they have one specific to your serger. Note: When you insert your needles (make sure they are #11 and #14 specific for your particular machine), the left needle will be the same size as right needle, but will APPEAR higher once both are pushed up into each of their respective needle shafts. Note: Hold onto needles or put a piece of fabric under the area when changing them/replacing them because they can easily fall out causing damage to your machine. Hope this helps. Jimmy
Mar 31, 2012 | Sewing Machines
Why does the 4th thread keeps breaking on my serger? I've re-threadedi it a dozen times carefully following the diagram. What am I doing wrong?
Most likely it is either your tension on thay thread being too high, or the needle is too big for the project you are working. Lower that tension, use the next size up needle, and thay should fix it. Also, I STRONGLY suggest only using maxi-locks thread. They are more expensive than other serger threads, but they are always half-price at hancock... Any other thread I have tried using causes breakage, especially on the the lower looper (the 4th thread). Although, of you keep the tension low-below 3 or so, you should be ok. If these tips don't help, I would also check your cutting width, if your machine has an adjustable one. If it is leaving too much gabric to the right of the needles, out is conceivable that this is putting too much pressure on the threads. Let me know if this helps!
Jun 23, 2011 | Simplicity Sewing Machines
I have a Huskylock 936 Serger and used it last week, no problem. I changed the threads for a new product and one thread came out and had to rethread. I know you have to thread the upper looper first then...
Recommend you remove all the threads and rethread from the beginning. ALWAYS RAISE THE PRESSER FOOT when threading and thread the upper looper first, the lower looper second. Sergers sometimes are temperamental about threading. When in doubt, start over from the beginning.
Jun 14, 2017 | Husqvarna Huskylock Computerized 936
Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at knowgodnofear@bex.net
Aug 10, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
209 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
