Question about Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver
Lost Tuning knob during accident.
Where can I get a replacement? The unit itself is working perfectly.
Did you lose the gray part and the white center part? Meaning that when you look at where the knob was, all you see is a hole with a green circuit board and a gold circle in the center?
I have a knob for you (gray part and white part). Write to me at mail@murphypatrick.com.
Posted on Oct 03, 2008
Front doors speaker not working but all the other are
could be a loose wire to the back of that speaker
May 10, 2014 | Cars & Trucks
I have bosch pgl985uc burner problem. The center burner will not stay lit. Seems other have had this problem. I ordered all new thermo-couplers. Installed, since Bosch changed them to a new part number...
If The Burner lights and stays lit as long as the knob is depressed, but goes out after the knob is released then there is a failure with the thermocoupler or the valve itself. The thermocoupler can be tested once removed from the cooktop - as follows
Heat the tip on the thermocoupler with a match or lighter and measure the electrical connection (other end) with a voltmeter - it should read about 15 mV or slightly more with in a few seconds. If no voltage is read then the thermocoupler is faulty and should be replaced.
The valve coil can also be tested for continuity at while the unit is disassembled. If no continuity is found the valve is faulty and should be replaced
The small voltage created from heating the thermocoupler energizes the coil in the valve which in turn keeps the gas turned on while there is heat at the thermocoupler.
Some units actually reignite the burner if the heat is lost and the control knob is in the on position.
Hope this helps ....
Dec 14, 2013 | Bosch PGL985UC 36 in. Gas Cooktop
Tunner circuit board
5140019-42 Tuning knob assy is the most common - it can also be the PCB but if the radio works but you can't change the station I would replace the tuning knob assy
Jan 26, 2013 | Dewalt DC011 7.2-18V Cordless Worksite...
I have a Comfort Glow ventless gas heater that we only use for emergency heat during the winter. The last time we tried to use it the pilot light lit perfectly and burned perfectly when the knob was...
This sounds like the connection for your thermocouple has lost a good connection.
Try this link to see how to properly clean and seat your thermocouple.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
Sep 27, 2010 | Cozy (W352E) Heater
Washer wont drain or spin
assuming urs is a top load machine.....Top load washers are designed with an interlock switch that stops the machine if the lid is opened during a spin cycle. This switch is operated by a post mounted on the lid that goes into a hole in the rim of the machine and pushes down on the switch, or a bump on the side of the lid right by the hinge that presses against a switch when the lid is closed, or as on new whirlpool models, by the hinge itself inside the machine under the top panel.
Determine which type you have. If it is the type with a hole and post, get a screwdriver and stick it into the hole with the machine in the spin cycle and the knob pulled out. If the machine starts, then the post is missing or broken. I have seen people replace perfectly good washers for the sake of this $2.00 part.
if it doesnt work... please get back to us with the make and model number of ur unit...
regards iversh
Sep 21, 2009 | Whirlpool Washing Machines
JBL Prius Radio Tuning Knob Broke
Search for your model number on eBay. You should be able to find used radios taken from a totaled Prius much cheaper than buying a replacement from Toyota.
Apr 17, 2009 | Car Audio & Video
Grundig Satellit 800 display problem
HI,
THAT IS COMMON WITH PLL TUNERS THAT THE SLIGHTESS
TWEAK ON THE TUNING KNOB WOULD MAKE THE DISPLAY MOVE .COMMON ON DIGTAL PLL TUNERS........
Nov 20, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Tuner
This sounds major.....
The signal detection used in both radios and TV sets is via special voltage sensitive diodes which alter capacity as the voltage across the diode changes.
You actually change the voltage across the diodes as you move the tuning dial.
In your case the diode only sees one voltage and is locked to a certain station, because you are not altering the capacity to re-tune to another station...
So it appears that you have lost the ability to alter the DC voltage across the diode...
The design of the tuning knob may be where this fault lies, where the physical action of turning the tuning knob does not transfer the mechanical action to the item that changes the DC voltage to the diode....maybe you have systen that uses a long cord would around pulleys that gives you nice control over the tuning maybe its just a broken tuning cord...
Maybe the tuning is done by just a simple variable resistor I'm not familiar with this system but I have given you the bascics to start on...Unplug the cord from the AC wall socket then remove the top of the cabinet and have a look to see what moves when you turn the tuning knob it will soon become apparent if there is nothing moving when you turn the knob and thus lead you on to the problem....
Maybe the knob is just loose on its drive shaft...
Cheers From YUBEUT
Nov 22, 2007 | Sharper Image SA253 CD Shelf System
Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver Logo
110 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
