Question about HP Office Equipment & Supplies
I have a Deskjet Printer 930C and the paper is jammed solid and I cannot release it. I am a home user
  • 1,031 Answers
HP printers have a panel door which you can open when a paper jam is usually located at the back of the printer.
Posted on Sep 21, 2008
  • Starnley Johnwells
    Starnley Johnwells Sep 21, 2008
    Step1Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
    Step2Turn off the printer.
    Step3Remove any paper trays. Inspect them for wrinkled or damaged paper.
    Step4Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    Step5If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
    Step6 If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    Step7 If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
    Step8Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    Step9If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Trying to print and an orange light is constantly flashing, checked ink cartridges and paper jams but no problem there
I have had this same thing happen to my 960c! The ink cartridges were new/full (but must have been faulty). I replaced them with different/new ink cartridges, which solved the problem.
Another idea is to uninstall the printer and install it once again.
Oct 03, 2010 | HP DeskJet 930c InkJet Printer
Indicator light reflects no paper, but after paper inserted the light continues to flash and the printer won't work
if you inserted the paper in your printer and you still having the error so this is not a paper error,
check is your cartridge carriage moving or not when you turn on the printer,
if the cartridge carriage not moving so this is might be the error of cartridges or cartridge carriage is not working,
try to remove your printer cartridge and clean it and if the error keep coming you need to take your printer to any local repair center. because its not a user service part.
Thank you for using Fixya
Jun 10, 2010 | HP DeskJet 930c InkJet Printer
Deskjet 930c; after a paper jam, the fault (middle)lamp keeps blinking. When I press it, a sheet of paper is drawn halfway through and a second press of the button completes the paper passing through. But...
there is a piece of paper left from paper jam inside the printer. open the printer in rear side portion and remove the paper inside. don't open in front of the printer it can damaged some mechanical parts of your printer.
Mar 22, 2010 | Office Equipment & Supplies
Paper is jammed and unaccessible to pull out is
Never try to pull paper from front cover, if cause mechanical damage to the device, Try to pull it from back of the printer or from paper tray,Visit this link to clear paper jam & Carefully follow the instruction:-
Have a nice day....don't forget to rate the solution.
Feb 20, 2010 | HP DeskJet 930c InkJet Printer
Out of paper error
Hi, the HP printers tell you what's wrong by using the lights on the front. Depending on which lights are on/flashing/off will give a different fix.
If you can let me know the sequence of lights (i.e. resume light blinking plus cartridge light on etc).
May 28, 2009 | HP DeskJet 930c InkJet Printer
Haven't correct driver
If it junks paper in tray, that it is not a driver problem, it is someting wrong with the mechanics.
In any case here is the driver.
Here is explained how to reinstall driver
Jul 08, 2008 | HP DeskJet 930c InkJet Printer
Paper Jam
I have exactly the same printer, here's how to remove jammed paper.
1. Unplug printer from mains and your computer. 2. Turn Printer around 3. There is a darker-grey panel with a knob in the middle of it. Turn the knob anti-clockwise to release the panel 4. The jammed paper should loop around the roller. Gently pull on the loop slowly until it has released fully. 5. Put the panel back on the printer and turn knob anti-clockwise to lock it into place.
Hope this helps.
Oct 29, 2007 | HP DeskJet 960c InkJet Printer
Deskjet 930c printer
Good for you for being on the internet and posting the question! The yellow light usually means, paper, ink or a jam. If it's got paper and ink, check for jams and even power cycle it and see if that helps. And try printing, it may just be reporting low ink. Good luck!
Jun 09, 2007 | HP DeskJet 930c InkJet Printer
93 people viewed this question
Ben Johnson
