Question about Dell Inspiron 1501 Notebook
Battery when I start up, it says it doesn't recognize the battery.
  • rlm111 Sep 22, 2008
    Thank you for responding I wish there was a way to fix it without buying a new charger.
    Scholar:
  • 110 Answers
Be sure to check the status of the battery in the bios. you can enter the bios by powering on the computer and tapping the F2 button on the dell logo. once in the bios check the status of the batter y and the AC adapter. If you get the message AC adapter type not determined it is a bad AC adapter or a bad motherboard (in most cases it is the ac adapter). if you get the message battery not recogonized try disconnecting and reconnecting the battery. if the message is the same and the system is outside 1 year from the date of invoice get a new battery as the battery has a one year warranty only. Try using a good known battery is available to test.
Rate if helpful.
Posted on Sep 24, 2008
  • Arjun Aukta
    Arjun Aukta Sep 30, 2008
    The problem comes up if the charger wire is shot so either you can cut up the charger and re-solder it (Thats what I did) but I suggest a new charger will be a better option.
It dose the same to me... and i fixed it by changing the charger.
Posted on Sep 22, 2008
Doesn t start
Check the 12 volt auxiliary battery, a low /discharged battery will shut the system down, there has to be 11.8 volts minimum, if less replace the battery.
Oct 04, 2017 | Toyota Highlander Cars & Trucks
No wifi
reinstall the WiFi adapter driver from Gateway support website.
Restart the notebook . Hope this helps
Apr 26, 2013 | Computers & Internet
2006 Prius - battery died, and after jump start, radio is acting strange.
The radio is likely in theft lookout due to loss of battery power. theft lockout.
Feb 01, 2018 | 2006 Toyota Prius
NOKIA C3 GOT WET NOW WONT READ SIM CARD PHONE LETS YOU START UP WITHOUT SIM
Turn off the phone and pull the battery out. Put a small amount of alcohol on a cotton swab and gently try to clean the sim connectors. Put again your sim card e turn on your phone. After that, if the phone doesn't recognize the card, try with another simcard if possible.
Sep 12, 2012 | Nokia C3-01 TOUCH AND TYPE QUAD BAND 3G...
My motherboard 945gct-m/1333 v3.0 doesn't recognize the PS2 keyboard and USB mouse.
Hello Nelson, most likely you may need a new motherboard. But here are some thing you may try before considering on buying one,
  1. try replacing a new motherboard battery.
  2. reset you bios. locate jumper cmos battery.
let me know your progress.
Nov 24, 2011 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
All warning lites are on but my car won't start
The following are to only to be recognizes as suggestions. With all the dash lights on this is one signal to narrow the variables preventing the car from starting. First thing I would do is check all the fusses, if they are good then go and turn off all accessories (radio, a/c, fans). then turn the key into the starting position and listen for a click noise. If the sound doesn't occur most likely the solenoid needs replacement. When the sound does occur the there are more variables. Low voltage (bad battery, battery cables loss or carotid). If they check out then this would be the last suggestion available. With the knowledge of the hazards would be to checked the started armature and brushes by jump the solenoid, if the starter drive doesn't spin then the start needs replacement, if it does it's beyond my knowledge and I'd be on my way to a professorial.
Aug 08, 2011 | 1998 Oldsmobile 88
While i was trying to update my nokia n73 turned off and now i can't turn it on,and my pc doesn't recognize when i connect the phone turned off
Did the update finished with out an error?check your battery,if the battery is too drained,you won't able to charge the phone.If this method doesn't works,there's a problem on the update process.
to be able to retrieve your phone,ask assistance to a mobile phone service near you.they will glad to assist you on your problem..
Jun 12, 2011 | Nokia N73 Cellular Phone
Dell Inspiron 1501 Notebook Logo
122 people viewed this question
Alun Cox
