Question about Refrigerators
Refrigerator door doesn't close
I have Samsung refrigerator RS253BAWW which is 2.5 years old. The door doesn't close. I replaced the gasket but the problem still exists. What else could I try?
  • kentjamesr Apr 11, 2009
    I have the same problem,the same age refrigerator and I will look for this tube now.Thanks
I ended calling a pro. The problem wasn't with gasket or hinge but with a tube that had ice deposited on it. This pushed my drawers towards the door and that prevented the door from closing. As epr him; it's a common problem with this Samsung model.
Posted on Sep 22, 2008
    New Friend:
This seems to be our do we fix this?
Posted on Jul 24, 2015
Mold on gaskets I like my Samsung refrigerator
Have you tried Clorox along with a fungicide? Mold usually forms on a moist surface. Is there any air leaks around the door seals? Sea Breeze
Aug 08, 2013 | Samsung Refrigerators
Door will open will not close
The door on a refrigerator is an important component to the over all functionality of the refrigerator. A simple refrigerator door repair can potentially save hundreds of dollars in energy every year.
Check the Hinges
A misaligned door hinge can release cold air from inside the refrigerator, causing it to run less efficiently. If the door doesn't shut evenly it could be a problem with a hinge. The easiest repair for this is to simply tighten the screws that hold the hinges. If this doesn't solve the problem try to see if the hinges are level. You may need to replace the hinges all together.
The Door Gasket
The rubber piece that circles the entire door serves a purpose more than just helping the door close quietly. It should form a seal that maintains the temperature inside the refrigerator. If the gasket is cracked or warped you will need to replace this. Find the model number for your refrigerator and you can find the right gasket. Some gaskets are simply put on with adhesives, others require clamps or screws.
The Light
If you have a faulty door switch, the light may stay on in your refrigerator. This wastes valuable energy. To check this simply find the switch and press on it with the door open. Sometimes a thorough cleaning of the switch can fix the problem.
By maintaining your refrigerator door and making the necessary repairs you can save yourself a lot of money in lost energy costs.
I hope this help in solving the problem....
May 08, 2011 | Frigidaire FRS26R4C Side by Side...
Refrigerator Model 596-65232403 2 Yrs old
Ed, check your freezer may be partially frozen or torn..RDS
Apr 23, 2010 | Refrigerators
My refrigerator door comes open easily when the freezer door is closed and goes unnoticed as it is barely pushed open. I have checked the door stop down at the right hinge, it is clear. The refrigerator is...
Try to re-adjust the appliance so it is level and tips backwards slightly. You'll have gravity on your side to help keep the door closed. You will need help tipping the unit while adjusting the levelers underneath.
Also make sure the appliance is sitting on a solid surface and isn't somehow twisted, which will place stress on the box and possibly cause the issue you describe.
Make sure the unit is not overloaded and that the gasket surfaces are clean. After only 5 years, the magnetic gaskets should not be worn out.
Jan 27, 2010 | KitchenAid Superba Architect KSCS25INSS...
Door on my samsung frig' will creep open
The fridge needs to have a slight tilt back so the door will close with ease!! also check and clean the door gaskets and metal surface that the gasket touches when the door is closed because there is a magnet inside the gasket and it will make a nice tight seal if all the surfaces are clean.If the gasket is torn it should be replaced
Nov 06, 2009 | Refrigerators
The refrigerator door (not the freezer door) does not close.
Is it closing flush when pushed up or is it not making good contact all around? 2 things can be wrong, the surround needs to be cleaned on the door and fridge and if it still doesn' stick you will need to replace. You can adjust the door slightly at the hinges but only if its loose should you need to. If its tight then it has not shifted and i would focus on the surround clening/replacing first
Oct 02, 2009 | Samsung RS2630SH Side by Side Refrigerator
Door gasket failure
DIY absolutely. Easy job with replacement part just re-thread the strip into the grove to replace.
Apr 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore Frig-bottom freezer/freezer door pops open
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
I hope this helps, and if you need more information On solutions just let me know, Thanks Sea Breeze
Feb 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frost inside freezer door
there is a small electric heater along the door gasket where you see the frost building up, this heater has apparently stopped working. this will also cause the door to pop open due to a poor seal. feel around where the door gasket contacts the refrigerator and it should feel a little warm. if not then a service company can replace those heaters. should not be too expensive.
Jun 28, 2008 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerators Logo
334 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
