White screen display
Am using veiwsonic VA1703w monitor when am in work with pc,
some times suddenly my monitor screen becomes fully white and light turned in to orange it repeats even when off and on the monitor.
it happens oftens.
it has no particular time to come some times at the time of start or some times in the middle.
pls solve my problem  thanks in advance
  • revi747 Sep 24, 2008
    hi, thanks for ur kind reply.I checkd the external power supply system as u said.Also i tried with voltage stabelizer but ddnt fix my problem.wot should i do, pls help me .........
    thanks again
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
Often, problems such as this is indicative of a failing capacitor in the 5V internal regulator section. Most capacitors uses a wet dielectric that dries out after some time due to heat buildup. In some instances, most of the capacitors would also fail ESR test. Additionally, you may want to check the external power supply if it is putting out the correct voltage as indicated in the reverse of the adapter box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 21, 2008
  • Louie  Role
    Louie Role Sep 25, 2008
    Further analysis of your description reveals that it is possible likewise that:
    • the backlights are working hence the "...screen becomes fully white...";
    • which also is indicative that the monitor is not receiving or processing the video signal;
    • the electronics were messed up.
    This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Screen is orange and pink where it should be white
Try updating graphic drivers from the HP website.
HP has a lotta tools inside, maybe one lets you run an updater HP Pavilion dv6405us Notebook PC Drivers Download
Feb 28, 2014 | HP Pavilion DV6405US Laptop
Acer x213w monitor
try to set up different frequncy of monitor....
try monitor with another comuter, or notebook....
let me know...
Jan 13, 2014 | Computers & Internet
I have a compaq FS940. It worked perfectly fine until a recent move were we had to diconnect everyhting. When i reconnected it all my monitor just instanlty goes to sleep. My modem works fine but the...
mdl34, Your monitor is listed as "time to retire" and get new unit on retrevo .com You might try "reseating" all the connections to the monitor and vga connector on the pc. examine all the connector "pins" in the cable connector and note any damaged or bent, crushed pins. Try moving monitor to a "known-good" fully booted pc to see if same problem occurs. Swap-in a good monitor to your pc to prove that pc is operating correctly. 12fixlouie
Aug 07, 2010 | Compaq Computers & Internet
Acer AL2216W's green light goes off completely when the computer is turned on. When I turn on the computer and monitor, there is green light on on/off button while an irritating Acer logo is showing up....
You may have failure in the power supply due to bad caps, bad inverter circuits such as shorted transistors, transformers, bad lamps. You need to open it up and make some measurement, see example of failed ACER monitors:
Post back what you see inside so we can guide you further.
Mar 13, 2010 | Acer AL2216W LCD Monitor
When I turn my computer on the monitor stays off. I press the monitor's power button and the orange light above it goes off, obviously turning it off. I press it again and the light turns blue, the words...
the monitor is not getting any video information from your computer .. check the connection at the computer to make sure it is fully plugged in .. make sure the video card (if it has one) is securely in place ... make sure the monitor is actually plugged into the right connector .. you may have a bad video card or a damaged cable to your monitor .. you can plug the monitor into another computer to make sure its ok ..
Feb 28, 2010 | LG Flatron L1750S 17" LCD Monitor
White screen on veiwsonic vg700b
Usually a completely white screen is an indication that there is no video signal being fed to the panel from the controller. For instance, if you take a working LCD monitor and just disconnect the video cable that goes to the LCD panel from the mainboard, it will turn on and off just fine, but it will light up bright white.
So, there seems to be an issue getting the video signal from your logic board to the panel. This can be caused by a bad cable, a loose connection, a bent and/or shorted pin (from plugging it in wrong), a bad logic controller chip, or a blown fuse/component on the LCD's circuit panel (PCB that runs across the top of the back of the LCD panel.)
Hope this help!
Feel free to contact me with questions, or for sales and service.
Boise LCD
(208) 891-9117
Nov 15, 2008 | ViewSonic VG700b 17" LCD Monitor
LG Flatron problem
i get a black screen and an orange light in my lg lcd flatron whenever i turn it on.. i cnt use my pc because of this problem.. i hope u would answer my question...
u can email me at
tnx man :)
Apr 09, 2008 | LG Flatron L1710S 17" LCD Monitor
I have a VeiwSonic Monitor model VA712b that went blank.
sell it.. the product and sevice from viewsonic in my opinon sucks nothing but problems tv less then a year old want to ship it back and forth to fix it piece of s**t
Feb 26, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
White startup screen
try this test: put pc into hibernate mode and allow full cycle. if monitor ceases problem, then original problem may be with pc's video output only.
Jun 08, 2007 | Hyundai ImageQuest L17T 17" LCD Monitor
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
Open Questions:
Computers & Internet Logo
683 people viewed this question
David Payne
David Payne
