Question about HP Compaq 6720s Notebook
Wont turn on blue led remains on
My hp compaq 6720s will not turn on, the blue power led remains on if the battery is in, if the AC is plugged in it still remains blue and if the battery is out with the AC in it is still blue, i have tried removing and replacing ram as i read on a hp troubleshoot page with no luck.
thanks for any help.
  • Anonymous Jan 08, 2009
    reset password in hp 6720s
Hp compaq 6720s display problems. The laptop is powered up the Power LED & Wifi LED are on and the fan board is rolling but no activity on the screen and it has been changed same result. What can
sounds like the video chip has gone bad on the motherboard, may have to have a motherboard replacement..to test, connect and external monitor and see if you get a picture.
Dec 30, 2013 | Computers & Internet
I have a Compaq 6720s Laptop, and I have plugged in not charging, and when unplugged despite saying 89% charged, turns off after one minute and thirty seconds
I suggest your battery has outlived it's usefulness. Perhaps you can get an even better one from an internet retail place. I've bought larger ones for various laptops and never had one fail prematurely.
Sep 29, 2017 | HP Compaq 6720s Notebook
Hp compaq 7620s wont start ( constant blinking blue light )
The adapter output appears correct, the batteries often work in that voltage range. But the problem you have is the motherboard, the HP line has constant trouble with the main board, only option is board replacement.
May 12, 2012 | Computers & Internet
My compaq presario 2200 wont boot up...when i press the on/off switch without the a/c charger (battery alone), the amber led flashes twice....if i plug the charger in with the battery, the led blinks once...
If the computer is not turning on, there is a big chance of hardware failure and normally there is no easy fix for this rather than a motherboard replacement.
May 03, 2011 | HP Compaq Presario 2200 Notebook
I have an hp compaq 6720s and my charge port light blinks rapidly, it wont let me charge my battery and the computer wont turn on when the battery is full any thoughts?
Usually a rapid blinking charge light is alerting you of a battery fault. Try taking the battery out, plugging your computer in, and turning it on (with the battery out). If it boots up, then your battery is to blame, call customer service right away and see about getting a new battery.
Mar 24, 2011 | HP Compaq 6720s Notebook
My compaq Evo n610c my battery wont charge when on ac power.The light for when the battery wont go on.
sounds like your DC coonector came loose from the system board.it is a common problem with laptops,
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
here is how to repair:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 26, 2010 | HP Compaq Evo n610c Notebook
Hp compaq 6720 laptop, wont charge battery, bought new battery have same problem. have tried several different chargers and they are all working, but not charging battery
If the notebook does not charge even after replacing it with new battery and checking with several chargers then it is laptop power jack issue.
You may need to replace it. However to confirm the issue is with power jack just remove the battery and try to power on the notebook only with AC adapter. If it does not then it is the power jack which is allowing the ac power to be charged.
If your notebook is in warranty then you can ship it to HP and if it is out of warranty then check the link below, you can purchase the power jack of the laptop from here.
http://www.laptopjacks.com/parts/HP-6720s-laptop-parts-466.html
May 27, 2010 | HP Compaq 6720s Notebook
The PC doesn't start. led is not blue when power cord plugged
Below is a link to the service and maintenance guide. This will serve as a reference for disassembly. It is free to use, copy and print. It is in PDF format. I would check the voltage at the tip of the adapter to make sure it is putting out the proper voltage. I have seen plenty if failures with the HP laptops at the DC jack area, in most cases these jacks are connected to the motherboard by a cable and plug, which makes them easier to service than the soldered type. Here is your guide........
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01550099/c01550099.pdf
Jan 13, 2010 | HP Compaq 6830s Laptop
Hi there, when I switch on my Compaq 6720s it powers up (you can hear the fan spin) then powers off immediately (LEDS go off) I have tried known good ram. Thanks
Have you checked that the power supply is giving charge to the computer, sounds like it's trying to run on battery power, but if the 'power brick' isn'rt working properly, this can give the symptoms you describe
Oct 29, 2009 | HP Compaq 6720s Notebook
HP6720s run slow when plugged in??
Start -> Control Panel -> Power Options
Ensure that when plugged-in, it is set to "Maximum Performance".
Apr 07, 2009 | HP Compaq 6720s Notebook
HP Compaq 6720s Notebook Logo
387 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
