Question about Belkin Computers & Internet
Just bought Belkin surge protector 8-way with telecoms.The 3 ports are lablled "output" (2) and input (1)>I have broadband external modem (ADSL) and internal modem for use with fax.The Broadband fiter plugs into the phone socket on wall and the B/B modem plugs into filter as does my phone extension. The problem is I'm not clear how this interfaces with Belkin unit. Any help much appreciated. Thanks
  • Belkin Master
  • 3,498 Answers
Does the surge protector have a "in and out" phone socket? Plug everything into the "out" side and then run a "phone wire" from the "in" side into the wall socket,.. you should be protected.. You are putting "all your stuff" after the surge protector.. so the surge protector can do its job..
Posted on Jul 18, 2017
  • 21 Answers
SOURCE: Hi, i have a belkin
Check with your Network provider, and ask them if they can run a line check. No adsl can be problem with either the line or hardware.
But before that do check with your modem as well.
Posted on May 11, 2008
  • 284 Answers
SOURCE: I live in New Zealand
check with your provider in NZ, they are the only one who can tell you if its work in NZ
Posted on Jun 25, 2008
  • 2961 Answers
SOURCE: Belkin F5D7630-4A ADSL broadband connection
check you have typed in the correct password and username for your isp adsl connection
Posted on Aug 18, 2008
SOURCE: Configuring DLink Wifi router for Reliance broadband
Reliance Wimax will be Dynamic (DHCP)
Step 1 :
Connect the Wimax wire from the wall outlet (power adapter provided by Reliance) to the computer directly. The computer must be in DHCP mode.
Check the IP Address of the Computer. It should be a public IP Address.
Step 2 :
Open a web browser. If you try to open any page, it will take you directly to the Reliance Broadnet Login page. Login with your Reliance User ID and Password. Then Log out.
Close the web browser.
Step 3 :
Now, connect the wimax wire to the WAN Port on the Router and the computer to any LAN port. You can open the Router Setup Page. Do MAC Cloning. Then, save changes. Run DHCP on the Router.
Also you can configure wireless network, by changing the SSID and security.
Step 4 :
On the wired computer, open web browser, go to Reliance Broadnet login page and login and start enjoying the service.
One problem, you might face is when the Router is turned off in between. You may have to repeat the Steps 1,2 & 3 to get the connection back.
Posted on Oct 20, 2008
SOURCE: I have a Belkin Wireless
Sounds like you have a bad router. Contact Belkin or if you've not had the device that long take it back to the store.
Posted on Nov 06, 2008
on Jun 25, 2014 | Dell Zylux Powered Subwoofer - P/n A425
How do i Fix New Nonworking Belkin 8 outlet surge protector? Plugged in once, tripped the circuit breaker, now doesn;t work at all.
The link you mention relates to Belkin's range of computer cards and network equipment. The drivers on this site will not help you at all since the Surge Protector is related only to the power supply to your machine. Its purpose is to prevent surges and dips in the electrical supply that might be harmful getting to your electronic equipment and damaging it. They require no drivers and have no means of applying them either.
If it blew the circuit breaker the first time you used it, and it doesn't work - anywhere - then its faulty. You mention that it is new, therefore don't make any attempt to repair it, open it or anything, just take it back to where you bought for replacement, since it was clearly not of "merchantable quality".
Hope this is helpful, if so would you please register that with Fixya
Dec 03, 2014 | Computers & Internet
Only one (out of four total) HDMI input is working on my set.
The HDMI switcher IC chips in TVs can be damaged but lighting hits near you house even if the power is protected with a surge protector. The damaging power comes in through the HDMI port and blows the chip out and it can affect just one port or multiple HDMI ports. Your best bet would be to just get a cheap HDMI switcher and use the one working port. The repair on the TV would require placing the control board and would run from $75-150 for parts plus the labor to install it.
Aug 16, 2012 | Televison & Video
I have two Panansonic KX-HCM130 cameras. I have them installed on a Belkin F5D7234-4 V5.5 Belkin router. They can be seen locally on the network with local IP address and
Download and install Webcam 1-2-3 >
or Direct link
To set-up /configure webcam 1-2-3 software for live streaming refer to:
Then follow the instructions from this page -> on how to configure Belkin router for Webcam 1-2-3 . Important! You must have a static IP address .To avoid port conflict, use a port other than 80 for HTTP streaming
And the manual for your Belkin F5D7234-4 router can be found on the link below:
Please let me know if you need further assistance on this issue .
Nov 09, 2011 | Panasonic KX-HCM10 Network Camera
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
4:1 multiplexer logic circuit diagram
Telecom - 56G 4:1 Multiplexer MS4S1V2M
56G 4:1 Multiplexer Product description ms4s1v2m_156_100.png The MS4S1V2M is a SiGe 4-to-1 multiplexer (without integrated clock multiplying unit) designed for use in telecom applications up to 56Gb/s. The module accepts input data rates from 0.5-14Gb/s with an input sensitivity better than 100mV.
The mux can be used with existing equipment to generate higher bit-rate streams for telecom and datacom applications. The broad bandwidth of the input allows operation from 2 to 56Gb/s.
rohs__49_50.pngThis product is RoHS compliant
Request Demo Model Number Availability Request a Demo MS4S1V2M contact us Request a demo Purchase parts Model Number Availability Price Get a Quote MS4S1V2M Contact Us Contact Us Get a Quote For international pricing please contact your local rep or distributor.
Rep & Distributor Listing
Terms and Conditions of Sale
Product performance Operating
(Gb/s) Input
(mVpp) Output
(mVpp) Return
(dB) Conn.
Type DC Bias
(V,mA) 2 - 56 290 490 10 1.85mm "V" -3.6,560 Product documentation Datasheet MS4S1V2M: datasheet 4 Nov 2008 pdf-icon2.gif 313kB Complementary products 1:4 DMX MD1S4V2M: 56G 1:4 Demultiplexer 4:1 MUX MS4S1V1M: 40G 4:1 Multiplexer 1:4 DMX MD1S4V1M: 40G 1:4 Demultiplexer CRU MC39R46M: 40G Clock Recovery Unit Driver Optical Modulator Driver Modules Support documentation AN07 Module, accessory, and instrument general handling precautions 1 Aug 2005 pdf-icon2.gif 137kB
Apr 08, 2010 | Microsoft Office Standard for PC
Can't Connect more then 2 devices, on my Linksys Wireless Broadband N router. Called Linksys tech support not helpful, the other devices are coming up with Parental Controls.
Can you explain about your network diagram, what type of connectivity you looking????
or you can connect your devices as per below:
1. ISP cable -> Router1's Broadband port
2. Router1's LAN1 -> Router2's Broadband port
3. Router1's LAN2 -> Router3's Broadband port
Mar 31, 2010 | Linksys Wireless-G Broadband Router
I have bought a belkin wireless g router. my pc is virgin broadband i need to connect an aspire lap top. where do i plug in to make the router work
If you have your pc connected directly to your Virgin Broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Jul 23, 2008 | Belkin Computers & Internet
Computers & Internet Logo
46 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
