Question about Toshiba Computers & Internet
When you turn it on . somethink blue comes up and turs off again
  • 75 Answers
Check ur hard disk.....better take a bckup and format ur hard disk completely
Posted on Sep 21, 2008
Hello I have a 20 gallon kobalt model 033204. I just replase pressure switch but does same thing. When I tur on the compressor jus build 50 psi and shuts off.
This usually occurs when the motors internal thermal / amp breaker opens due to overload or weak breaker. Use an amp gauge to test for too much amp draw. If amp draw is normal, then problem could be the in-tank check valve leaking pressure back to the pump overloading the system, or weak capacitor or weak breaker. Bypass the breaker temporarily if the amp draw is normal to test system. Good luck
Oct 31, 2015 | Psi Air Tools & Compressors
Sylvania LC 155sl8p Will not turn on
its a problem with ignition panel try to change ut its not an easy task though.
Aug 23, 2008 | Televison & Video
Hja8703 will not drain
before doing any of the below please try not to get any electric wires wet and make sure the plug is off oor better still unpluged....good luck.....tip be carefull not to pull any little wires off......it might have somethink stuck in the pump causing the machine not to empty the water (the pump is normaly found under the bottom of the washing machine) if you do undo the pipe going to the pump watch out because there is water in there most of the time.......also check the filter because somethink could be stuck in there (these are normaly found on the front of the washing machine under the bottom front cover).....be careful because a little bit of water comes out...
May 17, 2014 | Washing Machines
My tv when i turn it on, comes on then turs off again, with red led flashing
The red flashing light is an error code. How many times is it blinking?
May 28, 2011 | Sony Grand WEGA KDP-51WS550 51" Rear...
My pioneer head unit wont come off mute when i turn on the radio mp3 or cd player
It happened to me today and it passed after a while when i was arriving home. Try to reset it by taking the power source off for a couple of minutes then try again.
Don't forget about your system definitions, it will be restored to default.
May 21, 2010 | Pioneer DEH-P5900IB CD Player
I have a sony 60 inc rear projection lcd. the tv turns on ok, however, the picture and sound goes off and then comes on again. this happens every 15 minutes or so.
hello do these checks first Adjust the Picture setting in the Video menu (see page 49).
❏ Adjust the Brightness setting in the Video menu (see page 49).
❏ Check antenna/cable connections.
❏ Adjust the convergence again using FLASH FOCUS (see “Adjusting the
Convergence Automatically – FLASH FOCUS™ –” on page 33). if this don't work get back to me and we'll try somethink else thanks
shaun
Oct 13, 2009 | Sony KP-57WS500 57" Rear Projection...
My samsun lcd vont turn on
Sounds like the powerboard to your tv went out. It can be replaced/repaired. Call your manufacturer for technical support.
Aug 04, 2009 | Samsung LE37B550A5 37 in. HD-Ready LCD TV
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Computers & Internet Logo
21 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
