Question about Magimix 5100 Cuisine Systeme Food Processor
Replace motor Can you tell me how to open the base as I need access to replace the motor. Your help will be very much appreciated. Pervez.
  • Anonymous Nov 28, 2008
    drive shaft cover
  • 99 Answers
Torx screws under rubberfeet.
Posted on Oct 12, 2008
Can I change the plastic motor spindle on a magimix 5100?
Yes you can, you can "cut" it off with a soldering iron by melting a slot down one side. When banging a new one on you need to remove the base and suppert the bottom of the shaft with something solid underneath it. The whole motor assembly will be sitting on this as you bang the new sleeve on with a soft mallet. If you don't there is a danger you will wreck the motor and you cannot afford to replace that bit.
Aug 29, 2014 | Magimix 5100 Cuisine Systeme Food...
Magimix 5100
Motor base cover for dlc 7 super pro
Try buying a new motor base on eBay. It's actually quite cheap. If you are daunted by the shipping cost of this monster, you can always ask the seller to sell you just the brown bottom cover. Under each foot is a screw which attaches the molded base it to the rest of the assembly. It's a lot cheaper to just have that part sent to you. This works as long as you are handy in making the switch of the base.
May 27, 2014 | Cuisinart DLC-7SFP Pro Food Processor
Base gear for the top of the base
Carefully take it apart and clean it thoroughly. If you see any burnt wires, trying replacing those if you know how to replace one. As for the plastic gear on the power base, it can be easily replaced with any ordinary similar coupler of the same size, for example like the one KitchenAid supplies (Blending coupler 9704230). The only catch here is that you need to replace the coupler on the base of your choppers as well. This would be a better idea considering getting rid of the cheap plastic used in these blenders and the need for long-term use.
Jun 01, 2012 | As Seen On TV Magic Bullet Food Processor
Can't remove the container from the motor housing
It will be the blade holding the bowl on. The blade has become locked onto the motor shaft, in the end you are going to need to replace both. Take it to a K/A service agent.
May 22, 2012 | KitchenAid KFP750 Food Processor
How do i seperate the housing on a robot coupe processor
There are 4 rubber shoes on the bottom of the white or gray base. Twist & pull these out. With a TORX long shank screwdriver (nothing else works, trust me) there is a screw way down in each hole. After removing the screws a gentle but firm bump should loosen the base. If you ever need to replace the motor, on the top around the drive shaft you will see three round plugs/disks, remove them by prying up with a pocket knife (works best) this will give you access to the three motor bolts.
Feb 20, 2009 | Food Processors
DLC-7 missing a piece?
The workbowl has a spring-loaded assembly inside. You can see it through the plastic. When the workbowl cover is in place and locked, it depresses the button on the base. If this is not happening, then you need to determine whether the workbowl or the cover is at fault. Once you figure that out, you need to replace the faulty one. I usually get my replacement parts at GourmetDepot.com.
Dec 20, 2008 | Cuisinart DLC-5 Food Processor
Bravetti platinum pro
For any Euro-Pro problems call 800-798-7398 or visit their website
www.euro-pro.com
I lost my power cord to the platinum pro deep fryer and I was able to get it from them.
Apr 08, 2008 | Bravetti Platinum Pro Quad-Blade Food...
Magimix 5100 Cuisine Systeme Food Processor Logo
480 people viewed this question
Top Magimix Food Processors Experts
Oloyede Monsuru
ray gallant
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
