Drum wont turn on any wash cycle butit will finish program
  • davidq33
    davidq33 Sep 21, 2008
    water is not a problem machine will fill up and empty its just the drum wont turn gives a slight kick but thats it
I had a similiar problem with mine. Come to find out, I have a lint trap in the water line and when this filter becomes clogged it won't let water in or out. You might want to look at this area.
Posted on Sep 21, 2008
All the display lights are on and the door won't open but the cycle is not finished
inbuilt lid safety switch wont let the door open till wash cycle is complete and drum has stop all motion
if you cant open the door at all after cycle ends
turn off at the wall
if no better
could be a timer fault or faulty lid switch
May 31, 2016 | Washing Machines
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
My bosch classixx 1200 washing machine wont pass first cycle, it will take in water and the drum will turn and keep turning thats all it will do whats wrong. please help
THE PROGRAM IS FIXED IT WORKS LIKE A CLOCK TRY TO OPEN AND SEE IF THE PROGRAM IS WORKING YOULL HEAR AS A SMALL RUBNNING CLOCK PUT SOME LIGHT MACHINES OIL TO HELP ITS MOVEMENT IF NOT CHANGER THE PROGRAM
Oct 21, 2014 | Bosch Washing Machines
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
Drum on duet washer is not finishing load, getting stuck, wont turn
Hello
you need to clean the filer on the front of the machine , or check the pump for a faulty impeller , a good. Clean of all the draining system would be a great start,
Oct 08, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Wont finish wash and drain
I would turn off main power then open the controls looking for any burn parts on the power board before calling any one , how ld is this unit before yu spen too much get back to me
Dec 04, 2011 | Electrolux Dishwashers
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
there may be something stuck in the pump itself. hairgrips and brawires are a common find.
Jan 19, 2009 | Hotpoint Ariston WD440G Front Load...
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
