Hi I have a IBM laptopT42 .... my problem is that the screen on the laptop will only stay on for a few seconds before it blanks out. Works fine on the external monitor. Can you tell me what needs to be done ..... Thanks
    Brigadier General:
  • 6,966 Answers
Based on your description, the problem could either be:
  • CCF (cold cathode florescent) lamp; and/or
  • inverter.
Since the T42 works fine attached to an external monitor, we can rule out the video card. Similarly, since the laptop's display shows (even if momentarily), then the video to LCD interface in all likelihood is also OK. Again, the display showing is significant, it tells us that the components are working except they stop for some reason and most likely it is heat related. Possibly a cold solder, a loose connection and/or a dried up capacitor. You could actually verify this be shining a flashlight diagonally across the screen (once the T42 has booted) and some semblance of the desktop albeit dark would be slightly visible.
What is required is opening the LCD lid/panel to perform repairs. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 21, 2008
My HP laptop was working fine, and then suddenly the screen went blank. When I reboot, the power light stays on and you can hear the hard drive spinning, but the screen stays blank.
unhook all usb cables and power cable, take out battery. Hold down Power button for 60 seconds, which will get rid of all static electricity. Plug in all cables again and check.
If still facing problem there will be some connection issue inside the lap.
Please let me know whether this works or not.
Dec 20, 2010 | Computers & Internet
Hi, the backlight on my IBM T60 screen goes out after a few seconds. The only way I can get it back is to put the laptop to sleep and wake it up again which gives me a few seconds more of screen...
Could be the lcd inverter goin bad ,,thats what powers the lcd backlight,,so in this case check ebay or internert,,but either way cheaper and easier to fix bein the inverter,,right un lcd bezel ,,its in the middle on the bottom ,,one screw,,swap for new one and you should be in buissiness,,goodluck
Nov 20, 2010 | IBM ThinkPad T60 Notebook
Baclight only stays on for a few seconds on my
You might want to give this a try. Start Menu - Choose Control Panel. Then choose Power Options. You should have several options depending on performance or saving power. Choose Change Plan Settings, and adjust the display brightness to suit your needs.
Hope this helps.
Sep 28, 2009 | Acer Aspire 3680 Laptop
Turn on laptop and screen stays blank apart from
You probably have a problem with the operating system not booting up. I suggest re-installing Windows operating system.
Jul 07, 2009 | IBM ThinkPad R51 Notebook
My R51 thinkpad screen keeps flickering and is quite garbled it blanks out alot and stays black until you hit FN + F7 (the key to switch from laptop screen to desktop screen) in wich case the screen would...
Sounds like the lcd is toast.
Hook the laptop up to an external monitor and see if you get normal video. If you do, chances are it's the lcd. You'll have to replace it.
Jun 19, 2009 | IBM ThinkPad R51 Notebook
Ibm turns on than shuts down
Hi, May be the harddisk is not recognizing. Restart your laptop and go for BIOS and check whether the harddisk is recognized.
Mar 09, 2009 | IBM ThinkPad R40 2681
Blank light blue screen (NOT blue screen of death)
hi...some times norton uninstallations create this problem, in which norton also uninstalls some system file like virtual driver file, etc.! u can try these things :
1. use systen restore to restore ur previous settings
2. IF it don't works, reinstall window !
let me know if it helps....
Jan 01, 2009 | Compaq Presario 700 470024-192 Notebook
Screen is blank although sound and lights are evident
Try removing and reseating your CPU, video cable and or memory. If nothing stills hapens, your video card or chip may have gone bad. Please let me know if this works.
Dec 13, 2008 | IBM ThinkPad T43 Notebook
IBM T40 Screen goes off after few seconds
Here's a couple of things to try:
Power down and remove the battery. Leave it out until you are done with the following procedures. Remove the memory modules and put only one back in. Try to power up. If that works, replace the other one and power up. If that works, you're fixed!
If not, try to power up in safe mode and see what happens. If it comes up, try running diagnostics on the HDD. If that fails, try reseating the hard drive.
Let me know how you're coming along on this. May be able to come up with more ideas, if needed.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Nov 26, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
