Question about Sharp AR-5320 Black and White Copier
Sharp AR-5320 B & W Copier giving L 4 error msg alternatly
I have a sharp AR-5320 Black & white copier. When I Print (From Computer) OR copy any FIRST document it stop the printing process in midd a on the screen L 4 blinking alternately. When I restart my coper or run the #,Int,C,Int+14 Programme on it becomes good but after some time when I print the first page it repeat the same error. Some days before I installed a new drom, Cleaning blad and tonor cartradge.
  • Anonymous Sep 21, 2008
    I have exactly the same problem, anyone?>??
  • Sharp Master
  • 2,794 Answers
L4 is main motor drive overload. It could be a power problem going on with the copier. Are these copiers plugged into surge protectors?
If you can have a Sharp technician look at it, it would be a good idea to determine if the motor, power supply, or main board is the culprit.
Posted on Sep 21, 2008
SHARP AR 5320 PHPTO COPIER ERROR H-4
fuser error which could be a number of issues , press green copy button for sub-code
Aug 19, 2014 | Sharp AR-5320 Black and White Copier
Sharp ar 5320 hwo to repair u4 200
check the duplexer which is what is used by the copier to print on the other side of the copy
Aug 07, 2014 | Sharp AR-5320 Black and White Copier
Sharp AR-5316 device driver for windows 7
5316 copier doesnt work with win7.you should use win xp
Aug 01, 2010 | Sharp AR-5320 Black and White Copier
Problem with sharp ar 5320 copier
Sounds like a bad earth or loose connection. Try using the parrallel port instead, or take the panel off and look for bad connection
cheers
Nov 29, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 B & W copier giving F 5 alternatly.
thinksssssssssssssssssssssssssssssssssssssssssssss
Oct 07, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Copier giving L 4 error alternately
The only way to corret the problem is to replase the fixing unit... That is what the L4 is refering to. It is not reading the correct tempurture..
Sep 20, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 giving me L 4 error some time
Usually the error is caused by a main drive over load. The machine needs to be looked to determine if its the motor, power supply, or a board.
Sep 19, 2008 | Sharp AR-5320 Black and White Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Jan 27, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Black and White Copier Logo
265 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
