Question about Car Audio & Video
I have a Jensen VM9312HD and when my car turns on and the head unit starts up the volume is very loud and i would like it to be quiter when it starts but i cannot find a way to change it. can anybody give me a soloution??? thankyou
  • Shawn1116 Jan 27, 2009
    The volume starts at different levels everytime the unit is turned on but either way it is always very loud. I tried everything from muting it when i turn it off to turning the volume down but nothing works. ??????? i really don't want issues with it when i have had it only 2 days. any answers? thanks.
I just found out how to fix this problem. turn the volume to the level you want at startup, then hold the volume button til it beeps.itll start at that level then.
Posted on Feb 07, 2009
How do i hook up a ipod to the stereo?
You will need to use the Media link provided with deck (it should have come in box) If you had purchased the deck form a private seller you can find it on ebay here are the links for the media link and the ipod attachment cable...
Media Link http://cgi.ebay.com/JENSEN-MEDIALINK-4-iPOD-INPUT-VM9512HD-VM9312-VM9312HD-/230561415259?pt=LH_DefaultDomain_0&hash=item35ae88005b#ht_2062wt_905
Ipod Sync cable for Media Link http://cgi.ebay.com/iPOD-iPHONE-CABLE-MSR3007-MSR2007-VM9312-VM9312HD-UV9-/190448728210?pt=Car_Audio_In_Dash_Receivers&hash=item2c57a0f892#ht_2628wt_1139
Jan 08, 2011 | Jensen VM9312HD Car DVD Player
WHEN I RAISE THE VOL. KNOB... THE VOL GOES DOWN,.. ALSO WHEN I TURN ON CAR THE VOLUME IS ALWAYS LOUD..WHY?
chances are that you have a bad head unit one of the diodas may have burned out so take it out and disacembel it and check it for burnt places if its not major you can saulder it
Jan 18, 2010 | Jensen AM/FM/MP3/DVD/CD iPod-Ready...
How to set start up volume control
I read another post that says that if turn on the unit and set the volume where you want it at startup, and then press in the volume knob until you hear it beep, that locks in the current volume as the startup volume. I just read this, so I haven't tried it myself yet. Good luck!
Apr 12, 2009 | Jensen VM9510 Car DVD Player
Scource button is red but unit doesn't seam to have power?
your red ignition wire is not getting 12 volts. that is why the cd player will not turn on. to test your voltage either buy a voltage tester or take it some where to have them hook it up and test it
Feb 24, 2009 | Jensen VM9510 Car DVD Player
Jensen cd 2610 aux input has little volume
first of all the rca jacks in the back of your radio are for plugging in an amp, not your mp3 player. there should be an auxiliary jack(looks like a headphones jack) in the front of the head unit. if there is no auxiliary jack in the front then you will have to go buy a new head unit with an auxiliary jack.
Jan 27, 2009 | Jensen CD2610 CD Player
Jenson touch screen head unit is all hooked up properly in a 2001 honda civic if i turn it up to around 25 with loud off and bass down it will shut off for a few seconds and then turn back on and repeat...
the onboard amp in the deck can't keep up and overheats inturn shutting off the speakers , this is common in jensen touchscreens esp the 9412 9512 and the uv 8 best thing to do is buy a 4 channel amp and the problem will be solved sometimes running a bigger constant power wire to the deck will help a little but not much better off buying a 4 ch amp
Aug 12, 2008 | Jensen Car Audio & Video
Loud switch
Call Jensen on this one. I have no idea as I don't one this unit.
Apr 28, 2008 | Jensen VM9510 Car DVD Player
How to activate the "LOUD" in my Jensen UV8
customer support suggested this: Turn the volume control, and while the yellow speaker icon is still visible, press and hold the volume control until you here a double beep. This confirms the new volume setting.
Dec 08, 2007 | Jensen VM9510 Car DVD Player
Jensen vm9311 dvd indash volume is loud when i turn on car
Heres the best way to fix; Quote from manual "Programmable Turn-On Volume (Pg.12) This feature allows the user to select a turn-on colume setting regardless of the colume setting prior to turning the unit off. To program a specific volume level, push and hold the VOL/LOC/DV know (6) while the yellow volume bar is displayed on the screen. The unit will beep two times to confirm your turn-on volume setting." Ah i had the same problem. I turned to the manual and it worked for me :) Good Luck, Ern
Oct 23, 2006 | Jensen VM9410 Car DVD Player
Car Audio & Video Logo
144 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
