Question about ASUS P5S800-VM Motherboard
Memory My MBoard is a P5S800-VM. I have 2 x 512 MB DDR 400 32x8. i want to change to 2 x 1GB....but i found 64x8, 32x8. Can i use all low density or only 32x8? Thanks
Model gfxcel pc133 multimedia audio controller driver
Posted on Sep 28, 2008
I want to fixt audio on my board
Posted on Jan 04, 2009
Problem with upgrading ram on Asrock 775i65G Motherboard
Hello download the manual here:
http://www.asrock.com/mb/Intel/775i65G/?cat=Manual
It explains the problem.
You will need adobe reader, to read content.
Good luck
Feb 01, 2013 | Asrock 775i65G Motherboard
Fdmdgo-03014s
For a Chaintech 9BIA motherboard;
Motherboard chipset is an Intel 845,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
http://www.firingsquad.com/hw/168/Chaintech_9BIA/
PC133 (SDR Sdram at 133MegaHertz;
{Single Data Rate. The proper term, not just Sdram.
Double Data Rate Sdram is Sdram.
Double Data Rate 2 Sdram is Sdram.
Double Data Rate 3 Sdram is Sdram.
DDR Sdram, DDR2 Sdram, DDR3 Sdram.
Synchronous Dynamic Random Access Memory )
Low-Density, Unbuffered, Non-ECC, Cas Latency of 3
(Don't get some cr@p off of Ebay.
It's usually high-density, ECC, that was used by old server computers)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146305
WHEW! Unless you just want to run 1GB of ram memory, I would toss that board! (Two 512MB sticks) ->
-> Need two 1GB sticks of SDR Sdram at 133MHz
http://www.directron.com/ct128m72s4r75.html
$400 smakeroos USD!!
Bah! That is just cra-zy!
Maximum TOTAL Amount is 2GigaByte. (2GB)
Maximum Amount for EACH ram memory slot is 1GB.
IF, you only have ONE ram memory module ('Stick'), it goes in Slot 1. (DIMM 1)
That is the ram memory slot closest to the processor socket.
The Processor reads ram memory Slot 1 first.
http://www.cpu-upgrade.com/mb-Chaintech/9BIA.html
Regards,
joecoolvette
Nov 26, 2012 | Chaintech 9BIA (CT-9BIA) Motherboard
Want to upgrade my memory. What do I buy? What kind of memory stick is installed? DDr? , DDr2?,.
Here is the Crucial site that gives the specifics on your motherboard:
http://www.crucial.com/store/listparts.aspx?model=P5S800-VM
DDR PC2700 or DDR PC3200. Max of 2GB (1GB per slot)
Thanks for using Fixya.
Jan 01, 2011 | ASUS P5S800-VM Motherboard
I have 2 sticks of 512 MB DDR 400 pc3200 in the motherboard but when i use crucials scanner to find out what memory is compatable with my computer it shows 2 sticks of 256. This board is supposed to be...
hi
your motherboard supports following RAM only
Note: PC2100/PC1600 up to 3 DIMMs; PC3200/PC2700 up to 2 DIMMs; 1GB PC3200/2700 with 32 DDR chips up to 1 DIMM only)
Aug 04, 2010 | ASUS P5S800-VM Motherboard
Unit came with 2 256 mem sticks--bought and installed 2 1GB sticks(pc3200,400mhz,84pin,low density,DDR--unit will not boot
The 2 1Gb RAM are either the wrong type or they are incompatible.
Try to use the same brand and speed as the 256 Mb RAM that was installed in your Dell.
Jul 31, 2010 | Dell Dimension 3000 PC Desktop
Does GA-8I945P motherboard support high density memory?
You have 4 slots available. Each slot can take a 1gb non ecc memory module with the specs below.
4 DDR II DIMM memory slots (supports up to 4GB memory)
Supports 1.8V DDR II DIMM
Supports dual channel DDR II 667/533/400 DIMM
Mar 22, 2009 | ASUS P4VP-MX Motherboard
Memory Stick Installation
So it seems you got the DDR / DDR2 side of the equation correct, but unknown to most, there is 'low' and 'high' density memory.
The density of memory refers to the number of chips used to make the total amount of memory that your memory stick contains. e.g. High density memory has few, large capacity chips to make up the 1024MB of memory on the stick, whereas low density memory uses many, small capacity chips to make up the same 1024MB total on the stick.
Typically, if it is a low / high density conflict, it is the 'low density' sticks only that will boot.
Me, I purchase Kingston memory when I'm unsure what the motherboard will be, and it has never failed to work.
I fix computers.
May 19, 2008 | EliteGroup PM800M2 Motherboard
Memory upgrade for Dell Inspirion 4100 notebook
buy 1Gb -one ram, the rices for 512 and 1gb are more or less same now
Apr 21, 2008 | Computers & Internet
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
ASUS P5S800-VM Motherboard Logo
157 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
