Question about Lexmark Office Equipment & Supplies
A THIN plastic strip about 1/4 X 16 INCHES LONG HAS BECOME SEPRATED FROM MY X4270 PLEASE ADVISE HOW TO FIX
    Brigadier General:
  • 6,966 Answers
This clear plastic strip is responsible for telling the print head where it is horizontally. Pls note that it has black stripes almost like bar codes. Both ends of this encoder strip normally would have holes for hooking up to lock tabs on both ends. What is important is that this strip is embedded in a slot at the back of the print head that reads the bar codes/locations.
This page may shed additional insights.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 21, 2008
Had to replace head, now having timing problem
Timing fix One. Hope this helps. This is what I have found to be the biggest problem on a PT. Use thin plastic cutting sheets purchased at the dollar store' wall-mart. Remove plugs. Cut two strips as wide as timing belt and about 12 inches long, then roll them under the belt but over the timing gear they will grip and roll under. Plugs removed; rotate crank to proper crank position. Take your socket on the timing gear and rotate to proper position. The gear will slip between the two strips of plastic. After aligning marks rotate crank to remove strips. Then do the next timing gear. This keeps the timing gears from jumping a tooth after releasing the tension on the timing belt tensioner. If still out of time your 180 degrees out.
Jan 14, 2014 | 2003 Chrysler PT Cruiser
Yellow light keeps flashing underneath triangle- Error code 6480. Please advise what this means? many thanks
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also will fix a gap in the printing running lengthwise (not across the page like a clogged head).
Mar 09, 2011 | Canon MX700 Office All-In-One InkJet...
My lexmark x5630 x56xx series displays carrier jam the carrier bangs to the left, i saw a thin strip of plastic in the printer looks like its broken off from something please help
just try to fix it .but i think it is broken so you need to replace the broken part i advise you to show it service center.
Have a nice day and do not forget to rate please...!
Feb 03, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
The runner in the printer
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
May 08, 2009 | Lexmark Z845 InkJet Printer
Everytime I power up it says hardware error 0502.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. We will replace the printer, only if it is under warranty.
Apr 26, 2009 | Lexmark X5150 All-In-One InkJet Printer
Hardware error 0504
Thank you for contacting to Fixya regarding your printer error message 0504.
I would like to inform you that error 0504 refers to encoder strip.
Next, try to print the self test.
Your's Fixya Expert
Jeeth
Feb 02, 2009 | Lexmark X6170 All-In-One InkJet Printer
1981 corvette instrument panel lamp replacement
I'll tell you, but when you go to do it, you'll probably curse Chevrolet, your car, and me! lol!
You have to reach behind the dash. Even with the seat in the back position, you'll turn into a contortionist! Place an old couch cushion, or something similar on the ground/driveway next to the car, with the door open. Kneel on the couch cushion. Reach up under the dash, and back behind it, with your left hand, while holding onto the steering column with your right.
It's hard to describe this to someone who has never done this before. (Just think. You'll be the expert, when someone you know asks you, when you're done!)
You are feeling for a plastic bulb holder. This holder is about the size of a dime. It resembles one of a gas stove's knobs. It has a round base, and from the middle of the base, it comes up into rectangular shape. If you look at this -> T <- the base is the top of the T. Turn the T upside down, and you'll have the basic shape.
This plastic holder has the lamp bulb in it. You turn it to the RIGHT.
As you face the instrument cluster, it is turned to the Right. You just turn it one quarter turn, then it will come out.
Once you get one in your hand, you'll know why it was difficult to describe. You'll also immediately see how it turns in, and locks into place.
The bulb itself it extracted, by holding the bulb holder in your hand, bulb facing you. You push in, and turn the bulb to the Left.
It is at this point, that I advise you to wear some protective gloves of some kind. The bulb base, could be corroded down in the socket. You may exert enough force to break the bulb, and cut your fingers.
I advise Safety above ALL ELSE!
I also advise that you replace one bulb at a time.
Notice the brass metal ring around the bulb holder base?
This corrodes after time, giving a poor contact. You can take a little fine steel wool, and clean it up. Use care as the steel wool can catch, and bend the brass ring, misshaping it.
Behind the dash panel that you can't see, is a thin plastic flat strip.
Another thing hard to describe. Envision a large U shaped flat piece of plastic, on the back of your instrument housing. The U shape will be upside down, in relation to how it sits on the back of the instrument housing. It's about 1/32nd of an inch thick, and about 2 inches wide.
There are thin flat strips of copper, making a path all the way around this strip. There are holes in this strip, for the various lamp bulbs. The flat copper strips go around these holes, making a connection to the bulb holder. That's what that brass ring on the bulb holder contacts, when it's screwed in.
Jan 29, 2009 | 1981 Chevrolet Corvette
Lexmark x4270 wont feed paper
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... It should resolve the Issue......... Good Luck..........
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Small thin film fell out
Try to cut off a thin plastic strip. just try to copy that. it basically guides the cartridge on where to print. also i remember that it should have a spring connected to the holes.
Oct 04, 2007 | Dell 924 All-in-One InkJet Printer
Mechanism Error - Print Cradle won't move! - HP 5650
This "plastic strip" is called the "carriage encoder strip". This strip dictates the timing of the carriage assembly. If the end slots aren't broken, you can re-attach it. Otherwise, you'll need to replace it. They are about $10.
Jul 03, 2007 | HP DeskJet 5650 InkJet Printer
311 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
