Question about Krell KAV-300i 2-Channel Amplifier
Krell kav300i, increasing volume by itself.
After several months not in use, my krell has started to intermittently increase its volume by itself, its worse when cold but cant be trusted when warm either. it can go very loud suddenly risking damaging my speakers. i took a peek inside to see if there was anything obviously blown, but could see nothing wrong or smelling etc, its disconnected now in case it causes damage.does anybody have any thoughts on this?, thanks .malise.
  • 31 Answers
That is an extremely odd problem. I suggest finding a tech in your area who is familiar with the unit, or contacting krell directly.
Posted on Sep 26, 2008
  • 4 Answers
I have 20 year exp. with Krell. Contact me directly.
Steven Leckrone
The Service Department
203-331-0671
sleckrone@snet.net
Posted on Oct 22, 2008
Porsche cdr22 volume increases and button will not dcrease
Most of these things use an IC to control things like volume etc. Chances are that will have failed.
Feb 25, 2013 | Pyramid Cdr22kit Am-fm Receiver Cd Player...
Have a 1998 chevy c2500 with v8 vortec. would not start one day , did nothing to it , but started 2 days latter. couple months later it did it again. had it boosted off and took it to have battery,...
Check the hot wire going to/at the distributor .. a number of these were crimped on the wires insulation/casing and not on the wire itself,,, it makes intermittent connection.
..This is hard to diagnose,, your symptoms are exactly what this causes... Good luck...
Jul 04, 2017 | 1998 Chevrolet C2500
Will the amp play 2 ohm speakers
If your amp has ability to play 2ohms, then it will play. It will play even it dosn't have the provision. It might cause damage to the audio output at certain level if volume level is increased. My advice is to check your amp. or read the user mannual for perfact usage. Thanks
May 16, 2010 | Krell Showcase 5 5-Channel Amplifier
Insignia NS-A2111
Cant help with diagrams but have you tried "freeze". Its a spray that cools components to see if they are breaking down thermally which does sound a little like it could be possibly. The cold component then rights itself when sprayed for a little while till it get warms again.
Best of luck
Jul 16, 2009 | Insignia 120W DVD Compact Shelf System...
Volume increases on its own intermittently
When the volume increased did the display show it doing so as if someone was turning the knob?  I mean did the volume go from like level 15 to 30 or did the unit's level stay constant while the audio volume increased?
Were you alone or sharing the room with a jokester who has a universal remote?
Does this problem occur when the batteries are removed from your remote?
Are you sure the 'volume up' button on the unit itself is disengaging properly after being pressed?
Dec 18, 2008 | RCA RT2760 System
Starting problem
sensor on top of cylinder head for the cold start ,with engine in front of you right side of head at the front there are two sensors ,cant remember if its the first one or the second one though
Nov 03, 2008 | 1993 Mercedes-Benz 190
Tv wont stay off
Yes - a new more expensive TV that is not a throw-away model.
The problem is probably in the micro and will continue this intermittently - sometimes hot/cold can have an effect on when it has the problem. It will get worse and it will eventually need to be repaired...
Sorry for the bad news.
Bill
Nov 14, 2007 | Polaroid TTM-2004 20" TV
495 people viewed this question
Top Krell Audio Players & Recorders Experts
80stech
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
Are you a Krell Audio Player and Recorder Expert? Answer questions, earn points and help others
