Question about Emerson MW8102SS 1100 Watts Microwave Oven
Emerson microwave carousel part...
Hello my inner tray was broken during a recent move, how can purchase a
replacement carousel part?
  • Emerson Master
  • 9,086 Answers
Emerson parts are distributed by Fox International and their number is 800-321-6993.
Or you might try e-mailing researchdept@fox-international.com
Posted on Sep 26, 2008
Sharp Carousel convection/ microwave. The turntable/ motor coupling has broken where can I buy one? I live in White River Mpumulanga.My e mail adress is richardtaggart@msn.com
Looks like you have the purchase the glass tray in order to get the coupler. I would give Reliable Parts a call though phone # is 1-800-666-0313. Give them your model number and the name of the part you need.
Nov 29, 2010 | Sharp Carousel R530EST Microwave Oven
WE need a replacement glass tray
If the model number is correct, the glass carousel tray is available at repairclinic.com for about $30. The item number is 1206676. I hope this helps you.
Jul 22, 2010 | Emerson MW8107WA Microwave Oven
NEED A REPLACEMENT PLATE FOR EMERSON MV8992SB
If you are referring to the glass carousel tray, the only place I could find one listed was repairclininc.com. They have a 13 inch tray (part number 1206676) listed for about $27. I hope this helps you.
Oct 09, 2009 | Emerson Microwave Ovens
Broken door on my Emerson microwave (MW8985W)
You can order the outer panel. Its available at searspartsdirect.com for about $41. Just type in your model number and look under the "Door Assy" heading. To replace, just follow these steps:
You have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and any screws that may be holding the outer panel in place. Some panels are simply snapped in place.
Remove the broken panel and install the new one. Re-install the door handle and re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you
Aug 27, 2009 | Emerson MW8985W Microwave Oven
Mw8992rd seems to be working fine except won't heat food. timer, touch pad, inside light, carousel all work fine. tried different times and power levels but still no heat.
This sounds like a bad magnetron that would have to be replaced. There is up to 2000 volts stored in a microwave, even when unplugged. For saftey reasons I would strongly suggest you have a qualified technician check it out.
Hope this helps.
Aug 24, 2009 | Emerson Microwave Ovens
My microwave is not turning.The part hold the tray is broken. Not sure the name of the parts.
If the microwave is still heating, but not turning, the part you are talking about is the carousel motor. The carousel itself, is the small ring that the tray sits on.
If the motor is not turning, it can easily be replaced. You will need to remove the bottom panel (under the microwave) to access the motor and connecting wires. The spindle is the shaft that attaches to the carousel motor and is where the center part of the glass tray sits. The spindle simply lifts off the motor shaft.
Since you posted no brand name or model number, I have no idea how to identify a part number for you, or where to order from. If you still need assistance, please let me know. Post back with your information so that I may be able to assist you better. I hope this helps.
Jul 02, 2009 | GE JVM1650 1000 Watts Microwave Oven
GE Advantium oven (6 y.o.), has hot spots, makes unusual noise
The drive to the carousel is broken...and what you hear is the drive trying hitting the bottom of drive shaft* (cheaper to replace then fix)
Dec 11, 2008 | GE Advantium 120 Convection/Microwave Oven
Broken turntable
The owner's manual is online at:
http://www.emersonradio.com/owners/MWO%20manual/MW8992SB-RD.pdf
You can contact Emerson at their number in the manual for a replacement.
I always suggest that people place food (especially popcorn) off-center on the tray (not in the middle) because the heating is better, plus the extreme heat is not always applied to the same spot in the tray each time.
Food placed in the middle will not cook as evenly.
Good luck, and we appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Emerson MW8987B/W Microwave Oven
Emerson microwave Glass turntable replacement
The part number was shown as M0S0885 (or MOS0885) but it is listed as "no longer available". In some cases, two microwave-safe plates can serve as a makeshift replacement for a missing tray. You have to find a saucer that fits securely on your turntable support, though. I've attached a photo. One last option would be a Nordicware or Rubbermaid or similar wind-up carousel. Wal-Mart had them when I checked a few months ago, and you can find them on Google's Froogle site at http://froogle.google.com by searching for the key words: wind-up turntable.
Oct 10, 2006 | Emerson MW8168B Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
148 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
