Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage light turns on without disturbance.
Garage light turns on intermitantly turns on with no disturbances while closed and stays on. HELP! (liftmaster belt driven model) stays on all night.
    Problem Solver:
  • 8 Answers
Most likely the unit has a sensor that activates the light when you walk around or open the door.
if no one is in the room it should go off in 5 minutes, but if someone goes back in there to check it goes back on again.
Under the light cover there should be a switch where you can disable it or make it less sensitive.
Posted on Sep 23, 2008
Door closes then opens by itself
It sounds like the down sensitivity is set too weak. Try adjusting it a little bit stronger on the down setting.
Sep 12, 2014 | Sears Craftsman LiftMaster Chamberlain...
I replaced the caliber guide pins on a 2009 toyota corolla and now ABS light stays on.
hi.... you may have disturbed the wiring that goes to the abs sensor
on the back of your brake plate. there is one on each wheel. and the cable goes from the sensor into your boot to a connector you may have disturbed this. its behind the panels on the wheel arch. good luck.
Mar 31, 2014 | 2009 Toyota Corolla
Reset Do not disturb
Question is kind of Vague, so I'm assuming you are trying to turn off the Do Not Disturb (DND).
In the standby mode, press the do not disturb button on the base. The DND indicator will light and DO NOT DISTURB shows in handset display. To cancel, press the do not disturb button again.
Hope that helps.
Sep 18, 2013 | GE Dect 6.0 Phone Digital Answering...
Pilot light won't stay on
Dust gets inside the pilot safety during the months when it is not in use. Blow out the pilot safety without disturbing the flap. and retry.
ODS VENT FREE HEATER TUNEUP
Nov 12, 2012 | Empire ECS HearthRite HR18MN Heater
Program "Do not disturb" on business phone
It's pretty straightforward. You pick a spare button, dial FEAT 00 press the blank button (with a light) and press FEAT 01. There are considerations that I'll reproduce here.
Do Not Disturb (F01) 8
Use this feature to be able to press a programmed button to prevent incoming calls for the
extension from ringing (lights still flash). When Do Not Disturb is on, outside callers hear ringing
while inside callers hear a busy signal. You should use Do Not Disturb only if someone answers
outside calls for your extension when you do not answer them.
Considerations 8
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
■ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
■ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
■ To avoid missing calls when Do Not Disturb is not needed, turn it off.
■ If Do Not Disturb is active at a doorphone alert extension, the person at the doorphone hears
signaling, but the alert extension is not signaled.
■ Unanswered calls that are transferred from an extension with Do Not Disturb active ring at
that extension if they transfer return.
■ Extensions with Do Not Disturb activated do not receive Caller ID information, unless the call
is answered.
■ Users with Automatic VMS Cover Assigned or with VMS Cover turned on can activate Do
Not Disturb
to Send All Calls immediately to their voice mailbox.
■ Users with Call Coverage turned on can activate Do Not Disturb to Send All Calls
immediately to the covering extension.
■ You cannot use Call Screening (F25) when Do Not Disturb is turned on.
Carl
May 10, 2010 | Lands Phones
From the manual: You need to program a button with FEATURE 01.
¦ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
¦ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
in the group.
¦ To avoid missing calls when Do Not Disturb is not needed, turn it off
Carl
Mar 16, 2010 | Lands Phones
Do not disturb
there is a red illuminated light on the main base... press it and it will turn DND off :)
Aug 02, 2008 | GE 28111 Cordless Phone
How do you turn off the "Do Not Disturb" on the Model 21028GE3-A
its a glowing red button on the base. bottom right corner. push the glowing red button till its off, and no light. should work right.
Jul 18, 2008 | GE 21018GE3 Cordless Phone
"Do Not Disturb"
On the base unit, press the "Do Not Disturb" button. This button is located on the front right corner of the base unit. The button light should turn off indicating that the DND feature is deactivated.
Feb 05, 2008 | GE 25952 Cordless Phone
Hi sir
Sorry but you cannot. the mp3 will always be disturb by the incoming call or message. It gives a priority to call and messages since that is a phone ;-). if you want to play mp3 without any disturbance then i recommend you buy an mp3/mp4 player.
Please Rate Thanks!
Jan 16, 2008 | Nokia 6600
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
519 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
