Question about Fagor LFA-65 IT Dishwasher
Fagor Dishwasher LFA 65ITX
My Fagor dishwasher starts, then half way thru its cycle it stops and beeps 5 times. It says it is overheating. What can I do to fix it please.
SOURCE: fagor f1-48w
The machine won't go into rinse if the rinse isn't hot enough. Check the thermal trip hasn't operated and that the thermostat bulb us fully inserted into the pocket in the front of the boiler.
Posted on Jul 05, 2008
SOURCE: Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Posted on May 12, 2009
SOURCE: Bosch Dishwasher beeps during cycle
yes this does work , press the button marked 45 degrees and then switch on, . Thank god this works! should a stupid design and nothing in the instructions
Posted on Aug 16, 2009
  • 2605 Answers
SOURCE: After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Posted on Jul 13, 2010
  • 557 Answers
SOURCE: Dishwasher shows several functions at
shut the power off to the washer, see if it resets
Posted on Oct 29, 2010
Testimonial: "Thanks that worked!"
Dishwasher doors are balanced by a set of opposing springs that, over time, can stretch and or become defective.
Get your model number and look on line on an Google search or bing. One can find a number of sources for the needed parts to repair this problem.
Aug 21, 2015 | Fagor LFA-073 IT Dishwasher
Why does my fagor dishwasher stop mid cycle and show f 6 with several beeps
I have already provided answer to a later post on this topic. Heater problem.
Sep 19, 2014 | Fagor LFA-013 Stainless Steel Built-in...
Fagor LF 65IT beeps 4 times a few minutes after switching on and all lights flashing on display
This is a flood warning. You must have water in the bottom of your machine which has raised the float and activated the flood switch. Open the lower front panel on your machine and for where the leak is coming from.
Apr 03, 2012 | Fagor LFA-65 IT Dishwasher
Fagor dishwasher LFU-65IT, when switched on it sounds 9 beeps. have referred to manual which indicates that 9 beeps means "not even" please explain
Hello, mh
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
Aug 26, 2011 | Fagor LFA-65 IT Dishwasher
My door will not shut and there is no tension on
make sure the strike is adjusted correctly.. it may have gotten bent out of place.. the strike is the little metal tab that comes off of the top of the center of the tub and goes into the door when you close the door.
Aug 29, 2009 | Fagor LFA-65 IT Dishwasher
Problem with the distributor motor. It is a small white plastic part which receives water from the heater, and alternatively distributes water to upper or lower difussors. If the motor locks, or the internal sensor doesn't sense the position well, it will show F9. Motor can be repaired in most cases, and at last, it can be swaped
Nov 28, 2008 | Fagor LFA-073 IT Dishwasher
Fagor dish washer VFU-05S
What do I do to overcome the fault 'F3' accompanied by beeping ?
Jul 15, 2008 | Fagor LFA-019 SS Stainless Steel...
Beeps eight times
Correct - lack of water pressure at the dishwasher, not the same as whether there is pressure from the line going to the dishwasher. There may be a clog or a valve that is closed.
Nov 21, 2007 | Fagor LFA-65 IT Dishwasher
7 BEEPS!!!!!!!!!!!
Please contact the Fagor America Service Center toll free: 1-877-743-2467. A customer service representatives will discuss the problem with you. If on-site service is required, they will coordinate that for you.
Jun 15, 2007 | Fagor LFA-65 IT Dishwasher
Fagor LFA-65 IT Dishwasher Logo
87 people viewed this question
Top Fagor Dishwashers Experts
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
