Question about Panasonic Microwave Ovens
I bought the panasonic A574SB in January this year. Since having this occasionally the microwave part cut out after 6-10 seconds, at first I thought this was saftey device. the microwave will now not work it cuts out all the time after 6 seconds. Is this an easy fault to repair or should I be asking Panasonic to replace? Many thanks
  • Panasonic Master
  • 9,086 Answers
According to a report we received, if it stops after 7 seconds, it has a problem with the inverter.
Since it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
You can find an authorized Panasonic servicer here.
Posted on Sep 26, 2008
Microwave cuts off after 30 seconds
We would need to know the brand and full model number to be sure, but since you posted in the Panasonic section, I'll assume it's a Panasonic.
Panasonics have preset times in which it will shut off if certain failures occur.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Dec 12, 2011 | Panasonic Microwave Ovens
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Jan 04, 2009 | Microwave Ovens
Faulty Panasonic inverter dimension 4 combination microwave
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
Oct 20, 2008 | Microwave Ovens
Panasonic Microwave Problem
Even though these are different symptoms, the same part may be causing both.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Sep 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave cut out after 20 seconds
22 seconds maybe? The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 08, 2008 | Panasonic Microwave Ovens
My panasonic microwave model NN-A574SB keeps cutting out after 5 seconds. Is ther anything I can do to fix this? Do you know why it is automatically cutting out? Any diagnosis would be gratfully...
Could it be 3 seconds?
Aug 05, 2008 | Microwave Ovens
Hi there, I have a panasonic microwave which is a few years old now. The problem is that it goes for about 20 secs then stops, the display returns to the time and the light in the microwave goes out....
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 30, 2008 | Microwave Ovens
Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
1200w Genius microwave, about 4 years old. Has been working no problem until today. When I press start, its starts ok but cuts out after 23 seconds. It does this on every setting.
The 22 seconds is the giveaway. In most cases, this is a problem with the inverter or a bad magnetron.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 20, 2008 | Panasonic Microwave Ovens
Microwave is not turning
Probably the turntable motor has failed.
Has anything ever spilled down in the the floor of the oven?
As long as it's not due to an external cause, it has a one year warranty.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
Apr 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
207 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
