Question about Tomtom One XL GPS Receiver
Will not turn on if not plugged into car adapter
One xl gps have had for sometime but will not turn on unless i plug into car adapter - can you help ???
Battery is dead
Posted on Oct 11, 2008
Tom not working red light when plugged in
Contact me at: dworakowski.lukasz@gmail.com
Nov 04, 2011 | Tomtom XL 350 GPS Receiver
How do you get started... where do you plug in the gps in my toyota avalon? I have a 5045
Hello, If i understand correctly, you are just trying to set up your Magellan gps into your Toyota Avalon. First of depending on the kit you got for the bracket to hold the unit, it normally will have a suction cup, that secures the bracket, put the bracket on the window, normally to the right of driver view and toward bottom of window, then after putting mounting (suction cup and gps holder) on window, then mount gps in to bracket, now your gps is mounted at this point on window. Now, of course you have to plug it in. GPS kits when you buy them normally have a 110 power plug ( to plug into home outlet) and some will have with the kit, a 12 volt cigarette type of plug to plug in your car (which is 12 volt power) In your home of course you can charge the gps off your 110 power, and gps will run off internal battery for a few hours, but you will find out like with mine, that your better off to plug into car for power, because the internal battery does not last very long. I have a Magellan as well, and they are great units. NOW this being said, if you did not get with your gps a 12 volt car adapter for your gps, you will have to get one. ( unless you have a power converter, which takes 12 volt and converts it to 110 power, but that's another story and only recommended for devices that do not have 12 volt adapter capabilities)
In conclusion if you have the 12 volt adapter to plug in your gps, all you do is find your cigarette lighter, take out your cigarette lighter, put in glove box for storage, and plug your gps in your cigarette lighter, or any other 12 volt cig lighter plugin. That's all there is to it, and now you have power running off your car. Thanks mike , hope this helps
Jul 23, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
I somehow chose the language on my tom tom 335 s xl to dutch it speaks english but i cant read the dutch to change it back
Bring it back into the house (unless you have your software on a laptop) Plug it into the computer with the cable they gave you, then go to Tom Tom's website and follow the instructions for a reset.
Sometimes just plugging it into the computer will automatically reload the software menu.
Feb 23, 2011 | GPS
How can I charge my tomtom xl 340s with my computer or is there an ac adapter option? Is car charging the only method?
According to Bill, from the TomTom technical services, your TomTom will charge when plugged either to your computer or to your car, as long at your gps unit is turned OFF.
Mar 03, 2010 | Tomtom XL 340S Car GPS Receiver
Tomtom will not turn on
Charge it. pick up a wall plug charger as the car adapter or cigarette plug sometimes fails
Aug 31, 2009 | Tomtom GO GPS Receiver
Garmin nuvi 5000 wont turn on. I can plug up the usb up to the computer and the screen shows garmin logo with a gps connected to a computer like its charging. But when i press the power button weather it...
Your nuvi 5000 does NOT have a internal battery and that means that you cannot operate it unless it is connected to a 12 volt power source. Connecting it to your computer via USB allows you to install map updates, check for firmware updates, etc, but you will not be able to use it as a gps while it is connected to the computer. There is nothing wrong with your gps.
To use your gps in the home you need to purchase a 12 volt adapter, there are several types, plug the adapter into your wall outlet and connect your gps to it. If you can sit near a window it will help in picking up the satellite signal. Just keep in mind that you cannot connect the 12 volt power supply and use the usb cable at the same time. Enjoy your gps.
Jun 11, 2009 | Garmin nuviĀ® 5000 Car GPS Receiver
I have had my tomtom one XL for almost one year. The car adapter (charger) cord went bad and they were backordered on the tomtom website so I purchased a radio shack universal adapter for navigational...
More than likely the generic charger sent more than 5 volts to your tt and burned a few rectifiers. You could try and tell tt the original charger did this but if they say no you are out of luck. You could put it on ebay and get something for it.
Apr 19, 2009 | Tomtom ONE XL GPS
Won't turn on
Partial Solution
My Tomtom xl 30 (if it has not been used for a few hours) takes up to one minute of holding the power down to turn on. ie a reset!
Dec 27, 2008 | Tomtom One XL GPS Receiver
Battery question
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
Oct 08, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Tomtom One XL GPS Receiver Logo
49 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
