Question about Quinny Freestyle 4 Marina Stroller
Quinny freestyle 4; Flat front tyre, how dod I get wheel off so I can repair/replace it?! Thanks
Push in the black button in the center of the wheel. It appears to be just a small plastic "hub" but it's actually a button for installig/removing the wheels.
Posted on Dec 30, 2008
Broken front wheel on my Quinny Frestile 3XL (2004). Can I buy a new wheel
Good Morning
The Quinny Freestyle 3XL was discontinued in the UK some time ago and we are no longer able to supply spare part items for this model. The wheels for the current Quinny UK range are not compatible with the Freestyle.
If you are not in the UK please go to www.quinny.com and select the country you're in, then choose "Contact Us" to ask the customer service department in your country whether a replacement wheel can be obtained and also how much it will be.
Jul 23, 2011 | Quinny Freestyle 3 XL Stroller
I have a flat tire; we have replaced the inner tube once already--How do I get a new tire?
Before just replacing the tyre (if it's still OK), a flat may be caused by a sharp object sticking through the tyre, puncturing the tube. Carefully check the inside surface of the tube with your fingers for sharp objects.
The Freestyle 4 uses generic 12" tyres but the thread may be quite specific. The stroller may have come with 'slick-type' tyres that are no longer available. The newer Freestyles come with these tyres:
http://www.babycare.nl/tyre-125x225-for-pushchair-buggy-stroller-p-1868.html
I hope this helps.
With kind regards,
Erwin de Raad
Babycare.nl
Sep 15, 2010 | Quinny Freestyle 4 Marina Stroller
My quinny rear tyre is flat tried to inflate the tyre but still does not work what should i look out for
you have a few choices
but if you want a long term fix you are better off getting a new inner tube as once a puncture occurs with the quinny wheels they will carry on doing it but theey are cheap enough to replace via ebay for about £6
if you dont want to replace you will need to remove the rubber wheel from the hub as you would a bike tyre then remove the inner tube
pump the tyre up put in water so you can find the hole then fix with a puncture repair kit
if you want to carry on using you can fill the tyres with tyre weld as you would a car they dont puncture and makes the quinny a smother ride
and if all else fails you can buy a used or new pair of wheels from ebay between £15 and £30
hope this helps x
Dec 14, 2009 | Quinny Buzz Three Wheel Stroller
I need a new tyre for a quinny speedy
i need a front and 2 back wheels or tyres for my quinny xl freestyle
May 26, 2009 | Quinny Dreami - Black Bassinet
Can we lock the front wheel on Quinny freestyle 4?
Hi, yes you can lock the front wheels, at the front of the wheel there is a grey button. You slide it down this will lock them. regards Marie
Apr 27, 2009 | Quinny Freestyle 4 Marina Stroller
Tyres
I don't have Freestyler myself, but friend of mine here in Finland found small innertubes and outer tires that fit to Freestyler 4 in hardware shop. They cost only few euros (4-8 dollars?)
I don't know about could bike shops have those also?
Tuomo
Aug 10, 2008 | Quinny Freestyle 4 Marina Stroller
Spare tyre/wheel
You don't need a whole wheel, inner tubes are available at most cycle shops - it is the same size as used on the small bikes for kids (12 1/2 x 1.75 x 2 1/4) - they cost around £4.50 and if you're not sure how to fit it, then they could probably do that as well.
Jul 18, 2008 | Quinny Buzz Jogger
Tires for Quinny Freestyle 4 Marina Stroller
If purchased in Canada call Dorel Juvenile Group customer service dept - toll free 1-800-544-1108. They will require the model number and date of manufacturing which is located on the back of the seat of the Quinny Freestyle. They will then ship the tires directly to you. I needed to replace my two front tires on my stroller and with shipping and taxes it will we $22, the tires are $8 each. I should have my tires in five to ten days. Plus the customer service representative I spoke to was polite and very helpful.
Oct 18, 2007 | Quinny Freestyle 4 Marina Stroller
Quinny Freestyle 4 Marina Stroller Logo
374 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Al Toledo
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
