I have a Polaroid Delfinia 32" TLU032238 TV.I cannot find the code for remote control setup.Can you help please?
SOURCE: need remote control code for 32" X2GEN tv
Good luck. I have the same issue. No codes are available for the X2Gen. To make matters worse, it appears to use a non-standard frequency for the carrier signal, maening that other remotes won't work with the TV.
I purchased a learning remote, thinking I would just "teach" it the codes directly from the X2Gen TV remote. This didn't work either.
There appears to be no way to use any remote other than the one supplied with the TV. Whatever you do, don't lose it!
Posted on Feb 05, 2008
  • 1694 Answers
SOURCE: i need the remote control
www.remotecodelist.com .........T.
Posted on Apr 15, 2008
mattozan
  • 555 Answers
SOURCE: I have a proton PLTV-32
What is the maker and model of your universal remote?
Posted on May 08, 2008
  • 3422 Answers
SOURCE: just found original remote control
HI,
Please let e know the make and model no.of your remote.
Also let me know the make and model no. of your TV
I'll let you know the code.
Posted on Sep 30, 2008
Techjoel
  • 79 Answers
SOURCE: lost remote need code for universal remote control.
These are for a Universal Remote. They might work. If not please add the remote manufactuer and model # to comments.
NEC TV 070 130 134 040 056 007 019 024 004 213
NEC VCR 012 023 043 048 039
Good luck,
Techjoel
Posted on May 11, 2009
How to use superior 4:1 for polaroid tv tlu-519443
The codes to check with Poloroid brand TVs are; 1074,1079,1073,1077. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 14, 2014 | RCA DIRECTV Satellite Remote Control
Polaroid code for tv
2846,2841,2840,2847. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 17, 2013 | Meridian Point Mini Universal Multi...
Need code for polaroid tv for sky
I've posted a clarification request above. You need both the TV model number and the version number of the Sky remote to find the correct code. I install satellite systems - I have access to the entire code database for all versions of Sky remote.
Oct 19, 2011 | Televison & Video
No Comcast remote code
http://www.comcast.com/corporate/customers/customer_support/remotes.html
If you look at the instruction sheet for your remote under 'searching for your code' you will see:
SEARCHING FOR YOUR CODE
If your home entertainment device does
not respond to the remote control after
trying all of the codes listed for your
brand, or if your brand is not listed at all,
try searching for your code.
For example, after trying all of the
codes for your TV, you still cannot get
the remote control to operate your TV,
then:
1. Turn on your TV.
2. On the remote control, press TV
once. Then press and hold Setup
until the TV key blinks twice, then
release Setup.
3. Enter 9 - 9 - 1. The TV key will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing Power and TV.
Stop when the TV turns off. A
working code has been found.
NOTE: In the search mode, the
remote control will send IR codes
from its library to the selected device,
starting with the most popular code
first.
5. Press Setup once to lock in the
code.The TV key will blink twice.
6. To search for the codes of another
device, repeat steps 1 to 5, but
substitute the AUX key for the auxiliary
device you are searching for
Nov 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Can't find Polaroid TV Remote Control Programming
Tries this website.1-800-Remotes Factory Original.Get the original remote or very close to the original.
Sep 11, 2009 | Polaroid FXM-3211C 32 in. LCD TV
I have a Polaroid tv 32"lcd FLM-323B and the remote control rc -103 dosent work..i need the code..can somebody help me?
It is a long an tedious process, but I got the correct code, and my TV works fine. The following are the codes for Polaroids. Try them one by one, and you should find one that works
10765,10865,11262,11276,11314,11316,
11326,11327,11328,11341,11498,11523,11991,11992
Robbin
Jul 18, 2009 | Polaroid 1720-7 Remote Control
Sky remote do not work wit polaroid tv 3232
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Polaroid TV is 0765.
Hope this suggestion, helps you out. Please take a moment to rate this info, by using the rating system below. Thanks.
Jul 12, 2008 | Polaroid FLM-3232 Television
Element tv remote code flx-2210
For the Direct White remote it is 10178
Jan 18, 2008 | Televison & Video
Remote code
We had a slightly different problem. DirecTV listed many codes but none of them worked. I scoured the Internet and found one that did the trick - 10178! I hope that works for you. If not, the Polaroid codes that were listed (but didn't work for us) were:
10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328 and 11341.
Jan 03, 2008 | Polaroid 3211TLXB 32 in. LCD Television
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
