Question about Electrolux Vacuums
Where can i buy replacement foot and hose for a electolux xio Z1030C
  • 706 Answers
Try ordering from this site http://www.vacuums24x7.com/hoses.html
Posted on Sep 21, 2008
I have an Electolux Diplomat that is about 25 years old. A friend recently fixed the switch for me but now the cleaner is blowing instead of sucking. Hose is on correct end. How do I reverse it?
Withould opening your device it's not possible to tell you what's the problem.
Guess you should call your friend or atake it to a repair service to check your vacuum but it's quite probable you should start thinking in getting a new one.
Oct 19, 2015 | Vacuums
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
Electolux vavumn overheats shuts off
usually caused by a stressed out motor..... clean the hell out of it... hose, filters .... everything...there could even be crud down in the motor itself... which requires taking the vac apart and pulling out the motor...dont be afraid to take hoses off and wash them out and dry them before putting them back on.
Nov 09, 2013 | Vacuums
I have an older electolux vacuum. It says Epic
Vacuum either has a clog or full bag that is overheating the vacuum causing the thermal switch to shut it down.
Hope this helps.
Aug 14, 2009 | Electrolux Vacuums
Vacuum shuts off quickly...
don't sucktion the hose or change the filter if it has one or the bag.
Jul 19, 2009 | Vacuums
Where to buy t joint for electolux vacuume EL7020 powerhead?
If you still have your receipt i would recommend to contact electrolux at 800 896 9756 you have a 2 year waranty so they should be able to either replace your power head or refer you to a service station that can repair it
Jun 16, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Split main hose
You can attempt a repair, but you'll be luck if it remains satisfactory for very long.  The only real solution is a new hose.
Apr 20, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I ned a new hose 25 feet
Most repair shops have bulk hose, non-electric, that you can buy by the foot.
Apr 14, 2008 | Vacuums
BISSELL POWERFORCE BAGLESS UPRIGHT FOOT HOSE IS TORN
Take the top cover off, unscrew where the hose hooks onto the back, then you can get to it.
Nov 18, 2007 | Vacuums
Vacuums Logo
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
