Question about Dryers
LD505E Westinghouse dryer Wall mounting???
I have the dryer and the kit to wall mount it but there are no instructoins on how to mount it in the book.
IE: where the brackets go and measurements etc...
I presume the 2 brackets i got with the dryer are the right ones.
They are 2 bits of steal with a right angle,a hook and a base with holes for the bolts etc...
Please help!
ps: stange that there are brackets for this dryer but no instructions in booklet.????
E-mail addy is charlie_nz@hotmail.com
  • cakea2 Jan 19, 2009
    I have the same problem, incredible not to have any instruction, the brackets looks ridiculous, they surely can't support the weight! please help!
  • Anonymous Mar 11, 2009
    I have the same prob also...i hope someone can help!!!!!!
SOURCE: wall mount hardware
The bolt size you need is: M8-1.25 X 20.  20 is the length that I used and it works well.  You could also use 25 (which is a little longer) if you would like.
It took about 5 trips to Home Depot and Lowe's and a few hours searching the web before we got it right.
Posted on Oct 11, 2007
jerryg50
  • 1673 Answers
SOURCE: wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Posted on Jun 28, 2008
SOURCE: removing base from tv
I researched this problem on the net and found the solution. Someone on one of the posts said the base can be removed by taking out four screws - all from the back of the TV. One screw is the one closest to the power plug, the next screw is beside it, the remaining two screws are the corresponding screws on the opposite side of the base panel (still on the back of the TV). Once these screws are removed the base comes off including the mounting bolt and the rectangular shaped plastic panel. There are no electronics or any components inside the base panel, only the bolt and plastic base which are held on by the four aforementioned screws. It was very easy to remove!
Posted on Feb 25, 2009
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
  • 10865 Answers
SOURCE: 42LC7D-AB cant find bolts to fit for wall mount
http://www.scribd.com/doc/6399173/LGTV
here is the owner manual. look on page 16 and you will see one way to wall mount. Ragarding the size of the bolts needed, go to the hardware store and get one bolt of each size close to what u think u need and use the trial and error method. OR go to an electronics store and ask one of the techies. Be nice and they will help u for free.
Posted on May 02, 2009
Westinghouse dryer LD505E is to be mounted on a brick wall ,what size rawlplugs & screws are needed .I bought the wall bracket mounting kit
that unit does not have wall mounting information its user manual
or a wall mount bracket supplied with that dryer
its a 5KG dryer by the looks of it
thats means its load a with 5kgs of wet clothes on the floor
suggest to me its no meant to be wall mounted
http://laundry.manualsonline.com/manuals/mfg/whitewestinghouse/whitewestinghouse_dryer.html?p=7
wall mount kit might be say suit most dryers
you have to go by common sense
use bigger mountings and fixings that you think it needs
has to hold up on the wall
this much weight
the all up wet weight of clothes
the dryer dry weight empty
and steady any vibration with the rotation on full load
into wood walls depends on the thickness of wood
if into dry wall ...need to hit the wall studs centre
I would not try it
if going into brick concrete ...hammer drill in and . ranset bolts
Sep 16, 2016 | Dryers
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
Trying to figure out how to convert the base to a wall mount since it appears that it is set up to do this.
first get a wall mount kit. ikea sells them cheaply.
there should be 4 screw holes on the back of the screen. screws goes in there.
first drill 2 holes on the wall
mount the ikea kit using expanding bolt
then screw in the ikea kit on the monitor
just hang the monitor on the wall side.
but..... 15 inch is a bit smallish for wall mount... dont ya think?
Jul 01, 2011 | AOMNI Corporation Magnavox 15MF605T/17 15...
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
How to wall mount
u have to get a wall braked to do this.......go to a store where they sell televisons and they will help u with ur problem.....also it eill have a installation guide enclosed in the carton
Nov 28, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
What is the correct wall mount for this tv? and cheapest too! westinghouse sk26H730S tv (26 inch lcd tv)
You dont need a correct one you just need one wall mount that can fit 26 - 30 inch search wall mount on trademe or ebay realy cheap and they can ship it down to you thats the cheapest way
Aug 01, 2009 | Westinghouse Electric SK-26H730S 26 in....
Condensation is forming on the walls when I use my clothes dryer
Simpson may have a kit available for accomplishing this. Also, your dryer may have several optional ways of venting.
Mar 27, 2017 | Dryers
I just bought a second hand westinghouse dryer 6kg LD605E, the sticker on the machine is upside down and the seller told me that the machine can be used either way. it this true? thanks
The LD605 series of driers is wall mountable and stackable
When wall mounting, the drier is hung 'upside down' with the knobs at the bottom to allow access, by people less than 8 feet tall.
The original package came with wall mounting bracke, and replacement sticker for the control panel with the text upside down so that it would be right way up when the dryer was hung.
If you arent going to hang the dryer, examine one small corner of the label area, the original label may be underneath and exposed by removing the wall hanging label.
The current model in the LD605 series still comes with wall mounting kit
http://www.westinghouse.com.au/product/display/model/LD605EB
Oct 11, 2008 | Dryers
Dryers Logo
1,171 people viewed this question
Top Dryers Experts
