Question about GPS
Software Problem with Navman S70 3D
I am having a software problem with my Navman S70 3D Device. When I power up the device, an error message appears which says: Gwes.exe problem, the program will shut down''. Any help?
  • 11 more comments
  • Anonymous Nov 27, 2008
    i have exactly the same problem.help!!!!!!!
  • Anonymous Nov 30, 2008
    This is the Problem i'm waiting for a reply from navman now !!!!!!!!!!11
    "Application gwes.exe has preformed an illegal operation & will be
    shut down.If the problem persists, contact the program vendor."
    Program: gwes.exe
    Exception: 0xC0000005
    Address: 00023174
  • james754 Dec 13, 2008
    This is the Problem
    "Application gwes.exe has preformed an illegal operation & will be shut down.If the problem persists, contact the program vendor."
    Program: gwes.exe
    Address: 00023174
  • Anonymous Dec 20, 2008
    got the same problem since hard resetting during a caluclation of a route
  • Anonymous Jan 02, 2009
    Same problem - is there a solution out there?!
  • dave210558 Jan 04, 2009
    i have the same problem, during a route calculation the S70 froze i turned it off and on again and got the error message. tryed several times to reset but still the problem persists. will be contacting navman tomorrow. anyone any ideas? or amyone already contacted navman about this? if so what was the result.
  • Anonymous Jan 22, 2009
    I have exactly the same problem and its very annoying!
  • Anonymous Feb 05, 2009
    hi ive had the sat nav s70 for less than a week ,and it froze while out on the road ,this caused a big problem , no way i could fix this even by reseting it .my advise is don,t buy this item ,get a simple one you can turn off and on . dave
  • bramevans Mar 13, 2009
    I have the same problem. froze on travels through spain. right pain.. rang Navman they say to try re installing software with instalation disc. (fat lot of good if disk in UK). if that fails it will have to go back to them.
  • saka1 Apr 15, 2009
    i have a navman s70 went sking in france worked great on the way back 30 miles from calais it stop calculating turned it of then this gewes,exe error any soulutions?
  • tone7 Apr 26, 2009
    I had the same problem 'Fatal Application Error' also froze and won't let me press Ok button, also tried to reset but same problem. Totally lost without it need it for work, trying to find my way around London, back to the old way of Maps, until someone comes up with an idea....
  • Anonymous May 03, 2009
    FATAL APPLICATION ERROR
    APPLICATION GWES.EXE HAS PERFORMED AN ILLEGAL OPERATION AND WILL BE SHUD DOWN. IF THE PROBLEM PERSISTS, CONTACT YHE PROGRAM VENDOR.
    PROGRAM: GWES.EXE
    EXCEPTION: 0XC0000005
    ADDRES:00023174
  • simon123321h May 18, 2009
    I have exactly same problem with my navmanS70 3D.
You have to contact Navman from thier website and then return it to them and they will repair it for you
Stu
Posted on Oct 01, 2009
  • ajcsilva Sep 06, 2011
    The problem is how to contact Navman. The mail contact@navman.com returns the message saying "out of office". If I can't solve the problem I will never buy a equipment from this manufacturer.
Unable to get satalites
Posted on Jul 31, 2011
My navman model n268 less than 6mths old is stuck on open page and wont reset or anything
Dear shaneborland Try this:
  1. Connect your device to you PC, format it.
  2. Unplug,. wait for device to start, then plug again.
  3. Start your Desktop software and reinstall the software on your device.
  4. Recover the activation keys
  5. Reinstall the maps
Laurent
Feb 23, 2011 | Navman GPS
Screen is showing computer, usb connection, navman which are joined together by a serious of dots with the computer screen to usb connection showing green lights
The F20 Desktop Software and Service pack on the CD's from navman do not work, as you have seen. The solution is to go to the navman website and download this Service Pack
Be sure your f20 is connected to the USB cable and turned on displaying the USB Connection screen. Leave it on during the entire process.
Once downloaded, run this self extracting file and let it install automatically. After it is installed and ran.....you will see the same error again of failure to connect.
At this point you must reinstall the driver manually. Right click on your "My Computer icon, Select Devices, then properties on the navman. You should see a yellow "?" next to a statement "Unknown Device" in the USB devices. Click on the "Reinstall Driver" and select a specific location or the Have Disk button. The USB driver is now located in C:\program files\Navman\f20servicepack\USB directory.
You should get a button that now says Okay at the bottom, click onto it and allow the MS program to update the drivers. You should see the device screen change and say "This device is operating properly". You can then close the windows and run the F20 desktop program. It should connect then.
Jul 06, 2008 | Navman GPS
Navman n40i smart st compatability problem with vista.
Are you not able to run the activesync program despite the Vista warning? Did you try running it in compatibility mode? What happnes when you try to connect with sync center (what happens...any error messages)? Regarding the mobile device centre...did you check that McAffe and windows firewall is not blocking it from internet access?
Jan 26, 2008 | Navman NavPix N40i GPS Receiver
Fatal error on Navman S50
you will need to do a firmware revision update by first downloading the latest software for your device from this link http://www.navman.com/in-car/3294/Australia/Old-content/11816/11607/69895/ then doing a complete reload of map software and firmware after registering the device with navman.
if this answers your problem please rate my answer accordingly.
Thanks
Sep 14, 2009 | GPS
B2+ software update
Hi The B2 is not the device that requires ID updating but the navman F series module, as this is what actually displays the Caller ID. Go to the address at the end i've given you and it'll take to straight to the relevent download page and download your relevent F series download. http://www.navman.com/in-car/europe/uk/Customer-Support/Software-Updates/
Feb 21, 2009 | Navman F20 GPS Receiver
Navman se 3450 comm and baud settings
The correct baud rate etc settings are 57600, 8, N, 1 (ie 57600 baud, 8 bit, no parity, 1 stop bit). You can verify this and see other details of specifications at www.fingertech.co.uk/gps_navman_3450.html or www.pocketgpsworld.com/navman3450.php
The other thing you may have forgotten that you need is to install the Navman driver - unless you have done this, you will get a "card not recognised" error when you slide on the GPS sleeve. This driver, version 3.1.6, can be downloaded from the Navman website.
I don't think you need to set the COM port number as a number, rather you select the Navman driver and it automatically knows which COM port is associated. This is COM 6 on my setup, but might vary between devices?
The other thing that some GPS software requires is to know the "type of GPS receiver" - this is "Other NMEA"
Dec 08, 2008 | Navman 3450 GPS Receiver
F20 navman error
You need to remove the 2 screews from the bottom and then gentley prize the unit apart from teh bottom using a blunt broad knife will help if you cant have the plastic case splitting tools which are used in the trade,
then once apart the same side where the power button is you will see a microsd card its the same as in a mobile phone just pull it down from the top (its hinged at the bottom) then make sure the card is in correctley and then close it back and test (b4 putting the case back on) that will fix it we ahve a lot of these coming in and its where its been dropped etc and jumps out thats it
from fototime. co .uk
Oct 29, 2008 | Navman F20 GPS Receiver
Navman N40i compatability with Vista
Solution to get GPS Navman N40I working with Windows Vista.
I solver the problem (most of it) by uninstalling the old activsynk witch was delivered with the manufactory CD. Then I downloaded from “http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center.mspx” Windows Mobile Device Center. After installing this software I connected my Navman N40I to my PC and waited to for the Mobile Device Center application to load. When it tried to gain partnership with my GPS I removed it. Voila, and the SmartST Desktop 2006 SE application was able to communicate with my GPS.
Hope this will help you!
Kind regards
Mega A
Sep 24, 2008 | Navman NavPix N40i GPS Receiver
Software update
Navman in no longer offering support for it's iCN 510. I am really mad about this. I spent $400 2 years ago for something that will not have anymore update. Here is there reply when I wrote to them about it. Class action suit anyone?
Dear Henry,
Thank you for contacting Navman Technical Support.
We do apologize for the inconvenience. Navman has decided not to release further map updates for these device due to changes in technology over the last year. We have changed the chipset and software platform and are unable to update this device. The Navman 500 series was released with an updated map version last 2005.
If you need further assistance, please do not hesitate to contact us, we'll be more than happy to help.
Kind regards,
Ofelia
Technical Support Team
Navman USA
C/O Mio Technology USA Ltd.
47988 Fremont Blvd.
Fremont, CA 94538
Office: +1 (866) 962-8626
www.navman.com
Jan 26, 2008 | Navman ICN510 GPS Receiver
GPS Logo
3,680 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
