Question about ASUS WL-500B Wireless Router
Wl-500b disconnects regularly
The router automatically disconnects at the most random times, mainly when I try to download a bigger file (ISO) or try to listen to an internet radio stream, but many other times, too.
I didn't change anything about its original settings, and I see no reason for the disconnection. I have to use the "quick setup" option over and over again to make it work. :-S
Any suggestions?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 96 Answers
Is it a standard Router from ISP? they are usually of lower quality.. I don't use them massive difference all around with connectivity if you use Cisco Tp link etc.. When I changed mine I had permanent connection at 40 mbps down and 9 mbps up, old router from ISP 32 mbps down 1.3 mbps up..
Posted on Sep 03, 2017
5 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: exactly ASUS WL-500g, no internet connection
My advice and personal experiences with both wired and wireless connectivity, is if you wish to share files and internet connection, purchase a combined Modem/Router and not a seperate router to work along side your original modem. Your modem will send your router an ip address in turn your pc is sent one from your router and can get complicated; keep it simple! These are much easier to set up and control as one unit and if there are ever any connection problems you will know it's either a setting or a modem/router problem and not have to wonder ; is it the modem?; Router? settings? etc. As there are frequent loss of connections both internet and LAN it makes sense have one peice of equipment to maintain.
Posted on Dec 22, 2006
SOURCE: wireless wl-500b routing problem
minha internet tá caindo direto e não consigo entrar no modem
Posted on Jun 05, 2008
SOURCE: Asus WL-520GC wireless not working....
how to reset my asus router
Posted on Oct 07, 2008
hcsr
  • 65 Answers
SOURCE: Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Posted on Aug 23, 2009
My router disconnect frequently
Question: the connection to router disconnects OR the internet disconnects,
If router disconnect: then try being in range, choose a better spot, keep router in a good spot,
If internet disconnects, cal ISP get it checked, make sure you run ping test to make sure its consistent , here is an example,
E.g:
open run: type cmd, hit enter,
type : ping google.com -t
hit enter, it should give regular pings without timeouts....if too many timeouts, internet service has issues,
call them and report..
Nov 29, 2013 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
HOW TO UPDATE ASUS WL-AM604g Wireless Router Firmware I HAVE THR TRX FILE
1. Download the updated software from the vendor's web-site.
2. Connect your computer with an Ethernet cable, *NOT* via wireless, to the router.
3. Access the router's built-in web-server interface.
4. Navigate through the web-pages to the "update firmware" page.
5. Click "browse", and point to the file on your computer that is the updated software.
6. Click "update".
7. Hopefully, BC Hydro wil NOT cut your AC power while your router is updating.
8. The router will restart.
9. Done.
Dec 14, 2009 | ASUS WL-AM604G Wireless Router
I am not able to properly set up my network with an ASUS Wl-500B
Both routers need to be on the same IP scheme and subnet i.e. 192.168.0.X subnet 255.255.255.0. First, unplug the Asus router. Next, make sure you have connection to the internet by hooking directly to the Apple router. Once you've established a connection to the internet plug the Asus router into the Apple router but go LAN port to LAN port.
Mar 23, 2009 | ASUS WL-500B Wireless Router
ASUS router not working with VOIP in use
check your settings if you allowed more than 1 computer to connect to your router.
Nov 15, 2008 | ASUS WL-500B Wireless Router
Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Nov 12, 2008 | ASUS WL-530g Router
Wireless wl-500b routing problem
May 20, 2008 | ASUS WL-500B Wireless Router
Lost setup disk
Here's the manuals for your router, you can find instructions in the Quick Guides in there:
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=WL-520g
Here's a direct link to the quick guide manual, there's a lot of non-english versions on that site and it's a bit confusing to find the right file:
http://dlsvr03.asus.com/pub/ASUS/wireless/WL-520g/WL520gQSG_2598.zip
Jan 24, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Slow downloading
Hi, DL managers usually split the file into many pieces, but the DL manager tries to grab many pieces at once and often there haven't been enough Ports opened to allow for this so check that also. Sometimesya ISP don't like torrents anyway and restrict that those ports into and out of ya conection..
Aug 03, 2007 | ASUS WL-700gE Router
A new router, recognizes the printer (HP Photosmart) and still won?t print from a distant location on the network.
I?m not sure about this one, but I think you should make sure there?s permission to access (share) the printer in the router and/or printer settings. If the printer is connected directly to the router, check if it?s in the right port and you?re not sending a print request to a different port. If that doesn?t help try to set it to another port in the router.
Feb 22, 2006 | ASUS WL-500B Wireless Router
ASUS WL-500B Wireless Router Logo
61 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
