Question about HTC P3300 Smartphone
Phone not switching on
I had press clear storage and now the phone is not starting
    Problem Solver:
Remove the battry.re inset it then connect it to ac charger keep it for at least 6 hours to recharge. the amber led will light up while recharging. press on. if it does not on then do soft reset. the phone will then on. it will work
Posted on Sep 29, 2008
My htc leo is starting to freeze alot how do I fix that
I would say that you should try a hard reset.
HTC HD2 hard reset
If a normal reset does not solve a system problem, you can perform a factory reset. After a factory reset, the phone is restored to its default settings-the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your phone, and only Windows Mobile software and other pre-installed programs will remain.
There are two ways to do a factory reset. One way is perform a clear storage process through the phone settings. The other way is to perform a hard reset by pressing certain buttons on your phone, in cases when you are unable to start up your phone and enter the phone settings.
Warning! Your phone will be set back to factory default settings. Make sure that any additional installed programs and important data on your phone have been backed up before you perform a factory reset.
Important If Encrypt files when placed on a storage card is enabled, back up all files from the storage card before performing a factory reset (Clear Storage or hard reset) or updating the operating system. Otherwise, you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a HTC HD2 Leo hard reset with buttons
1. With the phone turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then press the END/POWER button shortly and release it. You will then see this message on the screen.
2. Release the VOLUME UP and VOLUME DOWN buttons.
3. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Sep 18, 2012 | Cell Phones
Nokia E63 formatin
Dear arun to format your phone switch of your phone and take the sim card of and memory card aswell press the volume down button and press the switch button then the phone will show you some options press clear storage then everything will be cleared good luck
Nov 25, 2011 | Nokia E71 Smartphone
All our contact phone number seem to be on the sim card and on the phone hpw do I delete them from the phone
There are two ways, by clearing the Device Storage or you can try a hard reset, here are the steps:
To clear storage:
1. Tap Start > Settings > System Tab > Clear Storage
2. Enter "1234" now tap yes
To Hard reset:
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of the device
2. Release the stylus and continue pressing the TALK and END buttons and you will see a message on the screen that says "This operation will delete all you personal data...." now press ACTION to proceed
3. Release the TALK and END buttons and then press ENTER on your device
GoodLuck!
eBookBoy
Jul 10, 2011 | HTC Touch P3450 Smartphone
How to reset my samsung galaxy
METHOD TO RESET GALAXY
STEP 1: Switch off your phone, remove its battery, and then place it back.
STEP 2: Now, hold the Volume Down button and Power button. And then release the Power button while still holding the Volume Down button.
STEP 3: Now you will get a list of options to choose from. Which would be like:
  • Fastbook
  • Recovery
  • Clear Storage
  • Simlock
STEP 4: There, choose the Clear Storage option.
NOTE: Use Volume UP and Volume Down keys for navigation and Power or Home button for selection.
STEP 5: Now confirm by pressing Volume Up button (YES) or Volume Down (NO).
That is it! Now, you Galaxy S will reboot and you will find that you have reset your Galaxy S to factory settings.
Jun 30, 2011 | Samsung Galaxy S GTI9000 Smartphone
Hi, phone has been switching itself off lately when im using 3g internet or sat nav etc, would struggle to reboot till i took battery out, it would then fire up. it has just switched off again and i...
You need to perform a hard reset. Unfortunately you will lose all data you have on the device. Please remove your microSD card to salvage the files saved on there after performing the reset.
Follow these instructions:
Hard Reset
  1. Remove the battery and replace it.
  2. Press and hold the Volume Button
  3. Press and hold the Power Button until the phone powers on.
  4. You should see a simple menu showing options such as Fastbook, Recovery, Clear Storage and Simlock.
  5. Using the Volume Down button to navigate, Highlight Clear Storage
  6. Press the Power Button to select Clear Storage
  7. Confirm your decision with Volume Up for Yes. If you feel like backing out, press Volume Down.
This will return your phone to it's original, out-of-the-box condition, software-wise.
If even, after the Hard Reset your phone still reboots, contact your Customer Service department for a warranty replacement.
Jun 03, 2011 | HTC Desire Cell Phone
I recently bought a Samsung Epic off the internet, come to find out, the screen is still locked. I tried figuring out the code and tried performing a hard reset, but no luck yet. Please help! :(
There's 2 options available.
1: Perform a hard reset.
1. Switch the phone off. 2. With the phone off, hold the Volume Down button, and while still holding the Volume Down button, firmly press and release the Power button. 3. You'll boot into a menu with a white background, small text and the little skateboarding Android guys. 4. Press the Volume Down button until you reach the Clear Storage option. 5. Press the Power button to select Clear Storage. 6. Press Volume Up to confirm the selection.Sit back while your phone reboots in its virgin state.
Or, you can contact the reseller and they should provide you with the code.
Mar 18, 2011 | Samsung Cell Phones
I have buy a new htc p3470 mobile fone.i have a
try a hard reset of your phone:
this will get you back to factory default and take you through wizard for setup.
To perform a hard reset
1. Remove the back cover.
2. Press and hold the SOFT KEYS, then use the stylus to press the RESET
button located below the battery compartment.
3. Release the RESET button, but
continue pressing the SOFT
KEYS until you see this message
on the screen:
4. Release the SOFT KEYS, then
press TALK/SEND to perform the
all your personal data,
and reset all settings
to manufacturer default.
Press Send to restore
manufacturer default, or
press other keys to cancel.
Clear Storage
Another way of clearing the device storage and reset all settings back to
factory default settings is to use the Clear Storage feature. You will lose all
your data and files on the device storage when you use Clear Storage, so
make sure to do a backup first.
Important If Encrypt files placed on storage cards is or was enabled before, then
backup all files from the storage card before using Clear Storage, hard
reset or updating the ROM system software. Otherwise you will no longer
storage card.
1. Tap Start > Settings > System tab > Clear Storage.
2. Enter “1234”, then tap Yes.
Your device restarts and displays the Quick Setup Wizard
Mar 27, 2010 | HTC P3470 Smartphone
How do i reset my mda
start/ settings/clear storage/ enter 1234 when prompted and the phone will guide you through the rest. make sure you have a good charge before starting.
May 12, 2009 | T-Mobile MDA
Hi actually i had gone to option clear storage n had cleared phone restarted n was askin to follow the instructions n i followed,at last option the asked me to keep a sim paasword n i had ,unfortunately i...
Keep Pressed the Power key, and then press the point where you inset you stylus for soft reset.
Then leave everything.
You PDA shall start formatting (Clear storage).
-Please Rate.
Dec 03, 2008 | i-mate K-jam Smartphone
I need to reset my password for my Sprint HTC Touch MP6900
Hard Reset
Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default, or press other keys to cancel.
Release the TALK and END buttons, and then press ENTER on your device.
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Another way of clearing the device storage and reset all setings back to factory default settings is to use the Clear Storage feature. You will lose all your data and files on the device storage when you use Clear Storage, so make sure to do a backup first.
Enter “1234” then tap Yes.
Nov 20, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
HTC P3300 Smartphone Logo
43 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
