Question about Ricoh Aficio 2018D All-In-One Laser Printer
Error code sc 541
I have a richo 2018d all in one copier machine. when I powered machine a error code genereted sc 541 what is the solution
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Posted on Nov 10, 2008
  • 4 Answers
Hi there
that is a fuser code your thermistor is bad
good luck
Posted on Oct 09, 2008
3 Suggested Answers
  • 4 Answers
SOURCE: err0r sc 541
Hi
good luck
  • 24 Answers
SOURCE: code 541
SC 541 is a fixing unit error, clean the thermistor and then reset the code by pressing clear(yellow) then 107 and hold stop(red) key for 5 to 10 seconds then the display change. now turn off the machine from main switch, wait for five second and then turn on the machine.
this will reset the SC541. in case if the problem exist change your thermistor and check the thermostat.
Posted on Oct 12, 2008
Err 553 Ricoh aficio 2018D
SC 553 is a fuser error code, could be thermistor or thermal fuse or fuser lamp
Sep 27, 2013 | Ricoh Digital Copier Toner for Aficio...
Error cod sc 541
This SC-541 code comes when the fuser thermistor fails ore contaminated or poor connecton finellay power supply bord defective most of this cases we find thermistor failure first replace the thermistor 90% your problem solves- thankyou
Dec 15, 2010 | Ricoh Aficio MP 1600L Black and White...
Sc 541 power off on
sc 541 is a fuser error. you have to reset the code. here are the steps to follow.
press clear mode button once, clear mode button is the yellow one
press 107
press and hold clear/stop red button until you see the screen changes to copy sp mode written.
press copy sp on the screen and off and on the machine
it should reset the code.
Oct 26, 2010 | Ricoh Aficio 1035 Copier
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Code error
Push Buttons in this order:
Yellow/clear key
7
and Hold Red/Stop key, for 5 secconds.
If this works, turn machine off/on, the code should be reset. Alltho the code may come back, when the Copier attempts to print a page. If this is the case, you need your Fusing unit Repaired.
Oct 26, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Err0r sc 541
Hi
good luck
Error code 541
hi!!!!
may be the drum is damaged
try to clean it use dry tissue
or
repkaced the drum!!!
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Error Code SC 541
Its a fuser code. Hold down both of the arrow keys for 10 seconds, then press enter. Select 2 for engine, ok, select 7 for data log, ok, scroll to 7807 and execute. exit all of the way out until you get back to engine, then select 3 for end. Recycle power.
Apr 01, 2008 | Ricoh Aficio AP600N Laser Printer
Ricoh Aficio 2018D All-In-One Laser Printer Logo
1,823 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
