Question about Kirby Vacuums
Where do i buy a new fan for my legend 11 - Kirby Vacuums
  • 120 Answers
Try hescoinc.com part number K-A1190789
Posted on Sep 22, 2008
This fan will not run. We do not have a model # but the numbers on it is:LOT NO. T-163 P/N 2030016H. Is there a wiring diagram we can get for this? It is a fan withat goes in a window and has an exhalst...
This is used in a Lasko 2155A window fan. It is best to buy an entire new unit. The motor does not seem to be available anywhere.
11/20/2015
Feb 26, 2011 | Dayton Vacuums
I have a 11 yr old Hampton Bay ceiling fan with light kit. The pull chain to operate the fan broke (evidently inside of the fan) and I cannot figure out how to fix it. Do I have to take off the light...
I'm unfamiliar with your exact model but your description makes it very similar to the "King of Fans" branded models I fitted in my house twenty years ago and have fixed a few times. It might even be that yours are made by the same company as Home Depot source their Hampton Bay range from a variety of manufacturers including KoF.
You are entirely correct that you can access the pull chain once you have removed the lamp assembly. If it's just the chain which has snapped then it's normally straightforward to remove the short piece from the switch and install what's left onto the switch, but if your chain is the typical ball and link type and is more than a few years old then replace it with a new one if you can obtain the right size easily. They're not expensive, and the old one will have wear and tear making another failure highly likely. If either of the switches has failed (the pull switch or the fan direction switch) then they're also usually easy to obtain from any electronics store at low cost or you can contact Home Depot regarding spares, also check here and here. Your total repair cost should therefore be no more than a few £'s, $'s or whatever else you use locally: far cheaper and quicker than fitting a new fan.
I hope that my reply has been of use to you and saves you a lot of time and money. Please take a brief moment to rate my answer.
Oct 07, 2010 | Vacuums
Replace Kirby legend II fan (impeller blade)
In order to replace the fan you will buy a 2 or three piece lexan fan kit containing the fan a spacer and shaft.
You must remove the carpet head and then looking from the back of the machine you will find a series of philips screws on the outer edge of the fan housing facing towards the front, several of which may be partly covered by the motor housing. You will remove the forward facing screws to allow the housing to separate and reveal the fan.
If you are lucky there will be a sideways hole through the impeller shaft allowing you to slip a nail through to help twist the saft to unscrew it while holding the fan .
The shaft will turn off revealing a threaded motor shaft with spacers which the broken fan will slide off revealing a second spacer at the back . Be sure to replace these spacers in the same order when re-assembling the unit. Secure the shaft hand tight. Post back to advise if you need further help
Oct 07, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby Legend 2 Vacuume cleaner
call Francois Gordon 27 11 476 1235
Rocky
Jan 03, 2009 | Bosch Turbo Jet Bagged Upright Vacuum
I don't know how to change the brush. HELP Kirby legend 2 vacumm
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=767761
Generic problem for all Vacuums
I don't know how to
Posted by mcwalworth on Jul 10, 2008
I don't know how to change the brush. HELP Kirby Legend II vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. To change the Kirby brushroll is to dial the belt off of the fan pulley and unlock the head to the bell housing, the head will come off. Then you turn the head over and remove the bottom plate by 2 levers the brushroll will be attached. Remove the brushroll and replace it with the new one with the screw head facing down to the carpet. Replace the bottom plate and install a new belt. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Hi I am looking for some where to get my kirby legend 11 vacuum cleaner serviced and probably a new brush head for it thanks
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=722285
Hi I am looking for
Posted by libbit1 on Jun 30, 2008
Hi, I am looking for some where to get my Kirby Legend 11 vacuum cleaner serviced and probably a new brush head for it thanks.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In most cities there are factory authorizes Kirby Vacuum dealers that also do service in most of the big cities other wise there are your local vacuum cleaner dealers in your area that also do service on the Kirby vacuums. When referring to the brush head are you asking for the bell housing or the brushroll. The brushrolls are very available @ either dealer but the bell housing that the brushroll fits into you probably will need to get that from the factory or the local vac dealers may have a good used one for less money or ½ the cost of a new one. Just a suggestion for you. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Jun 30, 2008 | Vacuums
Legend 11 Kirby, sometimes will not turn on
Could have a problem with the motor, may need carbon brushes, or other motor related parts. If the light turns on and off with the switch, then the switch is probably ok. There is a speed switch inside the motor casing that could be bad.
Feb 21, 2008 | Vacuums
Bad fan
Take off the bag and handle, remove casing, then you can remove the front casing to get to the fan. Turn the belt spindle to the right to unscrew it, then pull off fan and replace it with a new one. You may have to lock the armature to be able to unscrew the spindle.
Oct 26, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
27 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
