Question about Hoover Washing Machines
Hoover elite 1210 won't progress to the final 'spray and spin dry cycle'.
    New Friend:
Hoping to be of help after the spin dry wouldnt work on our hoover elite 1210.
It would do the wash cycle fine but as soon as it needed to drain, it wouldn't.
My handy man (Husband) is great at fixing things and opened the front panel by undoing the screws.
Near the motor on the bottom left, there is a wheel/fan looking thing.
(Turn the machine off first)
He tried to spin the wheel but it would only move clockwise and not anti-clockwise like it is supposed to.
So he gave the fan a few spins clockwise before giving it a gentle pull outwards in which it loosened the wheel and was able to move anticlockwise again.
We then turned the machine on and it started spinning and draining the machine.
This machine is a work horse and I refuse to get another. They don't make them like they used to!!
Mine has a leak and we use a drip tray underneath at the moment. So long as it works. I am happy.
Hope this helps someone else with the same problem.
Posted on Jan 09, 2016
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
  • 106 Answers
SOURCE: damp clothes at end of spin cycle
Time to check out and clean your filter...........
Posted on Mar 01, 2009
  • 225 Answers
SOURCE: Bad vibration during spin
Good morning! It's common to a washing machine to go out of balance everytime we exceeded the prescribed capacity load (as indicated in the enclosed manual upon purchase of the unit). the fitted new pump is not the source of such problem. Please try to review the manual of your machine and take note of the required capacity load which I think should not exceed 6kg. Best regards.
Posted on May 02, 2009
  • 713 Answers
SOURCE: Hoover 700LA: no wash cycles working but will
Hi just read your posting. Now what wash temperature have you selected for the wash ?Is it cold , warm, or hot?Does it start to fill at all for the wash cycle?I have the same model at home so I know the model well.If it fills and does not wash it could be the timer or the reversing module. please reply and I can guide you throe step by step to rectify this fault.By the way does it finish filling on wash and not start the motor at all?Hope this helps, awaiting on your response.
Posted on Jun 05, 2010
beltronic205
  • 1474 Answers
SOURCE: My Hoover Elite 1210 toploading washing machine
Could be bearings or more likely the concrete weight at the bottom of the drum is loos give it a shake from under to check...Good luck
Posted on Feb 09, 2011
Hoover elite washing machine
FIXYA has no idea of any parts for hoover machine . contact hoover direct
Oct 23, 2017 | Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
My Hoover elite 920 goes through it's cycle put
the pump is bad. not worth the repair bill. get a new washer
Nov 03, 2011 | Hoover Washing Machines
My Hoover Elite 1210 toploading washing machine seems to make a horrible off balance sound on the spin cycle - even when there is a small load on. What can I do to fix it?
Feb 09, 2011 | Hoover Washing Machines
I have a Hoover 550 MB Top Loader washing machine . The cycle won't move from wash to spin . it doesn;t progress out of wash cycle , it stays there forever .
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Oct 19, 2009 | Hoover HTC243 Top Load Washer
Washer machine problem.
Hello noemystotler
You said,
On the last spin cycle water, never stops keeps spraying. Triede different cycles same problem I even disconnected machine in same problem.
sounds like the timer is not progressing and is defective!
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Hoover 1300 washing machine
hi there this is a common fault you will need to replace the control module and selector switch/timer
Dec 01, 2007 | Hoover H130E Front Load Washer
My Hoover Model Not listed/stops during the cycle
the cycle timer is beginning to sieze because it needs oil. disassemble washer to the point where you can apply small drops of 30W machine oil to the timer's bearings
May 20, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
165 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
