VIA P4M266 Motherboard
I am having a VIA P4M266 motherboard of 2002 make. I am having two SDRAM modules of 128MB 133MHz.But the system is showing only 128MB,whereas when is run some software to check my RAM it shows that both modules in both the slots are working. That motherboard is having slots for DDR 266MHz modules with jumper settings,but recently I tried to upgrade my system with a 512 MB DDR 133MHz but the system didn't boot.
What may be the problem and how to rectify it?
Should I buy a new motherboard?
  • Anonymous Dec 19, 2008
    i need jumper settings
I wont to P4M266A-MLY motherboard's audio drivers
Posted on Dec 18, 2008
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
Unfortunately, this first generation P4 motherboards are a bit strict on the memories that they recognized. Your particular motherboard to my knowledge only accepts either PC100/133 SDRAMs or DDR200/266 which were made on or before 2002. This has nothing to do with frequency but with the recognition architecture of these older boards. Often newer memories would not be recognized or even if they are, the capacity would be halved.
Depending on the specs of your processor and replacement availability, you might be better off purchasing a newer motherboard.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 21, 2008
Drivers 7vba-2aa5
Hello the drivers from this site should fit your mainboard:
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Please unzip the files bofore you install.
Install the 4 in 1 chipset driver first and reboot.
Install next the sound driver.
Here is also the VIA site:
http://www.via.com.tw/en/support/drivers.jsp
Here is some info:
SY-7VBA 133
Description
- 66/100/133 MHz FSB FC-PGA 370 Based ATX Motherboard
Processor
- FC-PGA 370 Pentium III Processors with 100/133MHz FSB
- Socket 370 for Celeron Processors with 66/100MHz FSB
Chipset
- VIA 693A + 686A Chipset
- 66/100/133MHz CPU FSB
System Memory
- Three 168-pin SDRAM DIMM sockets support up to 1.5GB
- PC133/PC100 DIMM support
- Provides ECC (Error Checking Correction) capability
On Board Audio Subsystem
- AC97 CODEC on board to provide audio solution.
SOYO has closed there support site many years ago.
Good luck
Jan 11, 2013 | Soyo SY-7VBA133 Motherboard
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
Swapped in 2 ddr 512 266mhz sticks for, 2 sdram 512 133mhz sticks. no boot, only beeps, neither sticks will work in either slots. cpu has a athlon xp 2000 133mhz processor, is this the problem? Do I need a...
Your motherboard works only with 100 or 133 MHz memory modules.
You hear the beeps because the motherboard is telling you that the memory is not compatible with the board.
The processor is not the problem.
Don't forget to rate this answer if it helps
Dec 05, 2009 | EliteGroup K7VMM Motherboard
I have 512 sd ram but i another 128,128 sd ram do included but its not working how can i solves this problem
The D815EEA2 motherboard only supports 512MB RAM maximum - I'm afraid there is no way to add more to it.
From Intel's description of the model:
Intel 815 Memory: Three 133MHz SDRAM DIMM sockets. Supports a maximum 512MB of 133MHz SDRAM
Aug 10, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Can work Memory SDRam 128MB PC100 with SDRam 512 MB PC133
It wont work, it will hang ur system. Ur motherboard supports but using Mutli-frequencies RAM is not possible, either u use SDRAM 512 BM PC133 or ur 64/128 PC100 RAM, You cant use all together.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
Simply upgrade to more memory
G-Skill is what I put in all my custom built computers.  Search newegg.com and you will find what youare looking for.  You want PC2700 DDR.
Mar 12, 2009 | Computers & Internet
My motherboard model is p4m266 8237,via technology inc.
my motherboard is P4M266-8237 does it support SATA drive
Jan 30, 2009 | VIA Sound Cards,Converts Your PC or...
I NEED RAM
Hi zouganeli,
You can install one, two or three modules. Each memory module can hold a maximum capacity of 128 MB of standard SDRAM chips, or 256 MB of registered SDRAM chips so maximum memory capacity is 384 MB of standard SDRAM memory or 768 MB registered SDRAM memory.
Hope that helps
Take care,
Michael
Nov 14, 2008 | Computers & Internet
RAM installation
download express installation for bios update from http://www.updrivers.com/bios/Motherboard/Intel/12/176.html
put on one ram only in windows run your bios express installtion
file
Apr 13, 2008 | Intel D845GLLY Motherboard
Computers & Internet Logo
776 people viewed this question
David Payne
David Payne
