Question about Panasonic Televison & Video
Panasonic Stereo Video NV-HV61. Power cut at home and Video will ot switch on. power going in& Signal splitter working. Fuse not blown. Power aftr the rectifierbut I need circuit information to go any further.
catriver
  • 878 Answers
SOURCE: information code signals "2E"
birdy, this 2E is the code for voltage to the motor control is either over or under specifications. You might have a harness loose on the motor control board. I have run into a few of these where all it was, is one harness not seated all the way. I believe you can get to it by removing the back center panel and it should be down on the right. Check all the harnesses going to it. Reset them if possible. You can also try putting it through the self test. Press and hold the chime and xtra rinse button together for 3 seconds. When the display shows 0, press and hold the wash/rinse and soil level keys for 3 seconds. It should go in the self test mode. It will check all the componets. If it passes, it will display a PA. If an error exists it will display SC. Look for a code of 91. Catriver..post back
Posted on Mar 22, 2007
SOURCE: panasonic nv-sv120 power shut down
Regarding panasonic nv-sv120 power shut down: I replaced C1250 (680 uF/25V) and C1260 (1200 uF/10V) and after that is was working perfaect again.
Posted on Mar 17, 2008
SOURCE: Panasonic TC-25V50A TV circuit schematic
Success! After finding nothing with a visual check I dropped the set about 3inches and all is well. Must be a mechanical connection problem. Probably a dry joint, will resolder if it happens again. John
Posted on Nov 30, 2008
SOURCE: Panasonic NV-V8000 no apparent power ,fails to switch on
Check all the small size capacitors on the power board (switching ps). There is a small capacitor that will need to be replaced sooner or later. (They dry out with age).
Posted on Jan 19, 2009
  • 3 Answers
SOURCE: I have a Realistic STA-2100
Tandy Consumer Services (Radio Shack's repair shop) can fix it for you. You can ask for an estimate first, so you'll have a good idea of the repair costs. I have one of these units myself, and I used to work for Tandy. They have all of the schematics and parts that they'll need to repair it. You could probably have it done for less than $200.
Posted on May 04, 2009
How to add a Switch to Power on and Off HT830 . I just want to use this with my home Stereo System. Is there a Jumper to Install to bypass the CN 501 Socket
I would wire in an on/off toggle switch just AFTER the fuse that tends to blow out. Its the fuse discussed it another post here on fixay. Currently you can see it at the following address: http://www.fixya.com/support/t120423-display_front_dvd_player_not_working
The fuse mentioned is specifically a fast acting .0 amp fuse from Little Fuse Inc PT# 0491.400MAT1 (FUSE, FAST ACT 125V FA 0.40 Amps). I just ordered this fuse from Digikey.com because my display stopped working. Everything else on the stereo still worked, just the display would not come on. So, installing a toggle switch just after the fuse would seem to me to be an easy way to turn the display on and off, and still have the stereo functional.
Jul 22, 2012 | Panasonic SC-HT830V System
It has stoped all together no power is there a fuse
Hi there yes internal fuse may damaged or the power transformer is damaged & that;s why its not supply the power to the main circuit board. Also make sure the battery is working condition. How about the DC power ? Is that working on Power Adepter?
Jan 01, 2011 | Panasonic NV-GS17 Mini DV Digital...
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
Dead Set
Could also mean a blown fuse in power supply. Fuse needs checking first if it keeps blowing then yes could be regulator, filter cap or rectifier diode fault
Jan 06, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Hi my panasonic nv-ds65b keeps switching off with a red tear drop flashing can you help
This is a dew error indication. Try running the camera on AC adaptor with no cassette loaded for a couple of hours with power switch set to Off. RHN
Jan 01, 2010 | Panasonic NV-DS65 Mini DV Digital...
Flashing LED on the power Switch of the Panasonic NV-M3000
There are two components that you need to change in the power supply section.
1. Chopper transformer , T1001 (ZL6R23038)
2. CAP-P pulse amp transistor , Q1004 (2SD1624).
iam afraid you can only get these components from another 'dead' camera or order them from panasonic.
regards,
Luwangula
Sep 02, 2009 | Panasonic NV-M3500EN Camcorder
Dec 30, 2008 | Panasonic Televison & Video
Tape jammed error code el1 Panasonic nv-hv61 video player
Try pressing EXT LINK button on remote. The vcr is waiting for a command from an external link.
Apr 17, 2008 | Panasonic Televison & Video
Televison & Video Logo
127 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
