UPS Backup I have a XGEN UPS 500VAof 2002 make. It has suddenly stopped giving backupsupply. I bought a new battery but even that doesn't work. What mightbe the problem?
  • yettitracker Jan 27, 2009
    I have a APC CS 500. I've changed the battery externally, installed it and within 24hrs it went flat triggering a continuous alarm. I have checked, the unit is not charging. I now have 2 with the same fault. APC don't want to know... They just want to sell me a new one or more....
  • lamina Feb 10, 2009
    I have a Mustek PowerMust 800. I've changed the battery, installed it and within 24hrs it triggered a continuous alarm - the sound and the three lights on the front panel. Do not know what to do??
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
Initially, pls charge the battery outside of the UPS. Thereafter try again. If the unit will perform, it is just that the UPS is not capable of charging the battery from a flat condition since it is normally designed to cutoff below a certain voltage level, say 10.8 volts. In some instances, it could that the comparator circuitry that is responsible for trigerring on/off the inverter when the battery is at a certain level is defective. Due to the absence of a schematic diagram my end, it would rather be difficult to pinpoint the exact part unlike what was available for the Samsung SyncMaster 753S. If you would try to wing it, pls start with fusible resistors, presence of standby voltage (often 24V), charging voltage of >12VDC and a +5 logic voltage/supply. Pls exercise extreme care, the battery terminals have a relatively higher voltage (than 12) with respect to the chassis ground.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 21, 2008
UPS backup problem
Hi Shrichandra,
Make sure that the battery you are using from the APC UPS is the correct one for the EnerG UPS, just because it fits doesn't make it the right one.
If you need UPS, Surge, or Power Related help contact Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/ ** If this helped - click YES :) **
Apr 14, 2014 | Computers & Internet
My UPS burnt due to short circuit in main line. After that the UPS don't give back-up even for second. After recharging the battery and connected to the UPS, the UPS don't give power at the output from...
if there was a short circuit, chances are that its toast. get a new one. DON'T ATTEMPT TO OPEN IT YOURSELF. THESE THINGS STORE POWER SO YOU CAN BE ELECTROCUTED EVEN IF YOU UNPLUG IT.
Feb 02, 2011 | Computers & Internet
APC will not stop making noise even after I
Disconnect the battery(s) from inside. The backup batteries are still working...
Mar 12, 2010 | APC Back-UPS Office 500VA (BF500) UPS...
Microtek dual ups battery
yeah, you need to replace the battery with the same kind of battery installed in it or you may consult with the technical support of microtek nearest you.
Sep 12, 2009 | Computers & Internet
APC external Backup battery is not working plz
It may just need a new battery. The UPS will do a self test on the battery when you turn it on. It may have tried to read the battery and the result came back as "failed". The batteries last about 3-5 years, even less if you live in an area with bad power. The batteries are very easy to change. You can buy replacements at www.batteryinternational.com/apc-backups-es-be350es-ups-battery-ups-batteries-f1.html
Jun 08, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
UPS does not stand for 30 min
old and outdated get a new one used ones always have bad batteries but if you must get model number and search online may take a while but peruse through all the site thatsound promising and usually whalla
May 18, 2009 | APC Back-UPS CS 500VA UPS System
After spark apc ups stopped working
just check the fuse and mosfets(the one with 3 pin ic's) and replace if necessary
recommended to handle if u r a technician with soldering and component testing knowledge.
remove the battery and re connect after 2 mins
Sep 13, 2008 | APC (BE500U-WEB) (BE500UWEB) UPS System
APC back UPS 400 fails to give back up
I have the same problem with an apc smart-ups VS 650.
New batteries - charge in batteries is good (also tested under load).
When AC power fails, no power is supplied to PC connectors by the UPS.
UPS self test works fine. UPS does not report any problems via software - Power Management under Windows XP.
Oct 12, 2007 | APC Back-UPS 400VA (BK400) UPS System
Computers & Internet Logo
275 people viewed this question
David Payne
David Payne
