Question about Compaq V90 19" CRT Monitor
Brightness I have Compaq v90 monitor its brightness gets on and of, when i decreases it then it becomes little OK.
    Brigadier General:
  • 6,966 Answers
All CRT type monitors have an FBT that supplies the high voltage to the tube. Additionally, it also supplies the G2 voltage that is responsible for the screen voltage. Often the adjustment for the Screen/G2 requires a bit of tweaking after some time of usage. Incidentally, there is another adjustment in the same area for the Focus control. Of course, adjustment would have to be done on a "live set" and on the high voltage section, extreme caution must be exercised when performing this operation.
In some extreme cases, it could be a cold solder or loose connection in the squarish PCB at the very rear of the tube. Alternately, it is also possible for a capacitor that is nearing end of life (dried up).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 21, 2008
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
I AM GETTING TEARS AND EYE PAIN BEFORE COMPAQ 7450. HOW TO SET ITS BETTER SETTINGS?
Press the menu button and select the brightness,try decreasing the brightness.Also try lowering the constrast and other color.Hope it works.
Oct 20, 2012 | Compaq CV 7500 17" CRT Monitor
Monitor to bright
Decreasing Screen Brightness (FN+F9)
Press and hold the FN key, then hit the F9 key to decrease screen brightness.
Increasing Screen Brightness (FN+F10)
Press and hold the FN key, then hit the F10 key to increase screen brightness.
Mar 21, 2012 | HP Compaq nc6230 Notebook
How to make the images darker
Push the 'OSD' ("On Screen Display") button on the bottom-edge of the monitor.
Use the LEFT/RIGHT buttons to select BRIGHTNESS or CONTRAST.
Use the OK button to choose that selection.
Use the LEFT/RIGHT buttons to decrease/increase the BRIGHTNESS.
Use the OK button to confirm the setting.
Use the LEFT/RIGHT buttons to select CONTRAST.
Use the LEFT/RIGHT buttons to decrease/increase the CONTRAST.
Push the 'OSD' button to exit from the OSD.
Jun 01, 2011 | Acer AL1916W 19" LCD Monitor
SCreen resolution to bright
You need to decrease the brightness of your screen by using the buttons on you LG monitor. Push the menu button and then navigate to and select brightness. Now use the left or right arrows to either increase or decrease the brightness.
All the best!
damnor01
Nov 06, 2010 | LG Monitor
Don't know how to decrease the brightness. It's straining my eyes. When I push the front bottom Menu button, a rectangle appears with the word Brightness, but I can't find how to decrease it.
Here is a manual for a Daewoo Monitor. On page 3 it indicates that there are buttons that show a right and left arrow above it. When you have the brightness menu highlighted press the left arrow button to decrease the brightness.
Sep 29, 2010 | Daewoo F227B Monitor
How do i make my screen brighter on presario v2000
Decrease Brightness (fn+f7) The fn+f7 hotkey decreases the brightness of the notebook screen. The longer you hold down the fn+f7 hotkey, the more the screen dims. Decreasing screen brightness conserves power. » To increase screen brightness, press the fn+f8 hotkey.
Increase Brightness (fn+f8) The fn+f8 hotkey increases the brightness of the notebook screen. The longer you hold down the fn+f8 hotkey, the more the screen brightens. » To decrease screen brightness, press the fn+f7 hotkey.
Nov 03, 2009 | HP Compaq Presario V2000 Notebook
The brightness adjustment bar appears on the screen all the time
Press the menu button on monitor select the brightness press the menuside button increases or decreases.after select exit oress the exit button on monitor.
Jul 13, 2009 | Compaq CV 7500 17" CRT Monitor
Display is not stable.
There are a couple of possibilities and none of them lend themselves to DIY repair. It can come from arcing in a component trying to fail; you may be able to hear this (if present) by listening closely near the rear of the housing, preferably in a quiet room and near the cooling slits.
Another potential source is what is called a 'cold solder joint' that may look and even measure OK until a little more current is flowing through it.
Neither one is something most users should try to deal with unless you have some technical background since having a powered, open, circuit board can be very dangerous; there are voltages greater than 20,000 volts and several other innocent looking places with many hundreds of volts with sufficient current available to kill.
The only thing you should try on your own is cleaning the guts free of built-up dust that naturally accrues in any high voltage device. Pull the AC cord, ignore overnight, then remove the few screws you will find, often behind the bezel and perhaps a couple in the rear near power cord and video connections/cable.
I like to do this with the monitor laying face down on a soft surface so with most housing you can simply lift the housing free of the bezel and put it aside. With a vacuum cleaner and a clean paintbrush, clean all the areas you see that have obvious build-up of 'fur.'  Try not to disturb any parts in the process though, some are fragile. If the bottom of the circuit board is visible, clean that too and look for any dark brown areas caused by heat. These can become conductive if approaching black in color.
You will see a fairly fat cable leading from a black lump on the circuit board; this is a transformer responsible for producing the 20-25,000 volts. If the unit has been off overnight, you can clean enthusiastically around the rubber cap you see on the side or top of the picture tube; this is a good leakage point for high voltage.
If you do this and it didn't help, you will have to find a surviving CRT monitor tech to take it from there.
Sep 13, 2008 | Compaq V90 19" CRT Monitor
More Brightness
on the front of the monitor there are key buttons naming menu, ok button and left & right arrow marks buttons first press menu button then go to brightness then by using arrow keys you can increase & decrease the brightness once you are finished decreasing r increasing press ok button.& there are many other settings you can change like contrast etc....
Feb 07, 2008 | LG Flatron 775FT 17" CRT Monitor
Compaq V90 19" CRT Monitor Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
