Question about Dell A940 All-In-One InkJet Printer
Error 0502 Getting the 0502 error when turning on the printer error 0502 comes on the screen after the cartridge stall screen comes up and the printer stops
  • 3 more comments
  • lady_day_bey Sep 27, 2008
    I was trying to fix the problem of the paper pulling to the right, jamming the paper and in the process, now I have the 0502 hardware error code. Help before I toss.
    Frustrated!
  • Anonymous Sep 30, 2008
    0502 comes on when i turn on printer
  • Anonymous Oct 07, 2008
    I have this problem as well and when I open the lid the cartridgest usually slide to the middle and they do not do that but I can't get them unstuck. This happened last week and a couple hours later it worked, but not right now when it is really important...
  • Anonymous Oct 13, 2008
    I have the Error code 0502 also. I have tried turning it off, taking out the cartridges and returning them, but nothing has worked consistently. anything to do besides pray when I try to print would be greatly appreciated.
  • Anonymous Nov 21, 2008
    YES! 1/2 way through the page, it stops. Printer shows 'hardware error 0502' and a window comes up on the pc 'cartdrige stall'. I went to Dell support/printer and typed those messages in the search and they give a very detailed description of how to reposition the encoder strip. It may help some of you...unfortunately, not me.
Take turkey baster or air can blow dut from cartridge area then restart worked for me.
Posted on Jan 11, 2009
502...error is 2 possible problems...ink dried on bar,,use alcohol to clean,,or u have bent or damaged bar,,when replacing ink cartridges...Try cleaning inside good ,with cotton ball,,,then take turn printer upside down,,and shake gently for 10 seconds..if this doesnt work..then u have buy new printer...
Posted on Oct 22, 2008
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to remove the cartridge of your printer
and put back on!! properly!!
may be your printer cartridge
not in ilignement!!!
Posted on Sep 21, 2008
Error is Cartridge stall, hardware error 0502. Help?
Check this article on how to resolve a Hardware Error 0502 on LCD Display: http://bit.ly/UVCOPu
If it doesn't help, you would need to purchase a new printer.
Nov 19, 2012 | Lexmark X6100 Flatbed Scanner
Only prints to four lines of page. error 0502 comes up on screen. thanks
The 0502 error indicates either a problem with the encoder strip or a faulty black/color cartridge. Refer to this article from the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display to determine the cause of the problem and resolve the issue. If error continues even after following the steps, please contact Lexmark technical support for additional assistance. Thanks.
Jan 07, 2011 | Lexmark X6150 All-In-One InkJet Printer
Replaced black cartridge, color fine, but keep getting notice "hardware error 0502"
Hardware Error 0502
Hello there
Ok it is.
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Somehow it presents a drag on the cartridges and causes an error
And maybe put a little bit of oil on it with a cloth not too much.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 07, 2010 | Lexmark X6170 All-In-One InkJet Printer
Getting hardware error 0502
Hardware Error: 0502. On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
send you the link where you can figured out
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
sourav
Jan 05, 2010 | Lexmark X6170 All-In-One InkJet Printer
Lexmar X5150 Printer whit Hardware error 0502, can you Help Me?
http://search.lexmark.com/printer/US/en/17K0000
Download and install updated drivers from this link. If you need a walk through e-mail me your number and I will help you if you rate this fixya. Geokohler@gmail.com
George
Jul 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150 not working
Normally when an error 0502 shows on the printer display, there is likewise a pop up window in your PC's display that shows "Cartridge Stall". This indicates that the slider rod (where the ink assembly slides along) is gummed up with residual ink. Corrective procedure would require simply cleaning the rod with paper towel or something similar. A thin coat of lubrication would be nice aper the wipe down/cleaning.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 27, 2008 | Lexmark X5150 All-In-One InkJet Printer
Cartridge stall
I have a lexmark x5150 printer, scanner, copier, and fax machine. I keep getting the message: hardware error 0502. The cartridges are stalled on the left side and the printer won't do anything. Can someone help me??
Feb 18, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark 5150 - Error 0502
1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
2. Select the Solution Center.
3. When the Solution Center appears, click on the Maintenance button.
4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
6. Print the Print Alignment page to ensure the print quality is satisfactory.
7. Close the Solution Center.
Jan 07, 2008 | Lexmark X5250 All-In-One InkJet Printer
I have had this problem "Hardware Error 0502" which kept getting worse until I could not print any more. So I open the cartridge cover & removed both good cartridges, pushed the cartridge carrier fully to the right hand side & with one slightly damp cloth, a dry cloth & a pair of latex gloves (as the ink stains your skin) I first carfully cleaned the guey head like things on the bottom inside the printer on the left hand side. I removed a load of hard & soft gue with the damp cloth then finished with the dry cloth. Next I cleaned the bottom track aswell, moved the cartriage carrier fully to the left hand side to clean the rest of the bottom track. I then re-installed both cartriages & the printer is now perfect again!
Oct 26, 2007 | Lexmark X5150 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
96 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
