Question about Akai PT5492S 54" Rear Projection Television
Fungus in blue crt Akai rear projection
Do you have the instructions to replace the coolant for this?
Red looks great.
Blue has a small amount.
Green has degraded considerably.
  • tvplas Sep 21, 2008
    Absolutely I will tackle this project. I have been repairing consumer products on a personal level for 30 + years and have a small shop in my basement so no fear digging into this item. It is nice however to go in informed if possible so what ever you have I am sure will help.
    I do have the service manual.
  • tvplas Sep 29, 2008
    Ok, this is actualy a Samsung PT54925S with the Akai name on it.
    Below is the pdf of the service manual.
  • 2,326 Answers
Click here to find information on how to replace the coolant on CRTs.
Good luck and let us know the outcome.
Posted on Oct 09, 2008
  • 203 Answers
I don't have a pdf file for fungus in an akai, but you will need to remove the 2 tubes from the set, take off the cover for the reservoir and dump out the fluids and then fill them back up. you will then need to know how to do the convergence alignment after you put the tubes back in. This is a involved process, if you want to tackle this on your own let me know and we will see what we can do.
Tim Nolan
Posted on Sep 21, 2008
What does it mean if the color looks red?
That is usually caused by bad CRT coolant in the green and Blue CRTs which males the Red CRT dominate. Looking into the lenses of the blue and green will verify just compare them to the red. If they all look the same then the coolant is good and you have a Red CRT issue which will require replacement in most cases.
Aug 29, 2011 | Philips Magnavox 9P6034C 60" Rear...
My mitsubishi vs 6047 has been in unheated storage for about 4 years. now picture is very blury. when words are on screen large letters are legible with small white horizontal lines dancing side to side....
Does the picture look like this?
If so I believe your CRT liquid coolant has gone bad and needs replaced.
How to diagnose bad CRT Coolant:
Note: This problem will only affect the GREEN and BLUE picture tubes. The RED CRT is never affected, because the wavelength of the red light does not promote this algae growth
General Symptoms: Washed out, blurry picture, red portions mostly OK, GREEN images have halos, BLUE portions of images may have halos or be missing entirely.Turn the color level control all of the way down and remove the screen and/or the cabinet that contains the mirror. (different for different models) Do not turn the set off or the color level control will reset to preset levels. Look directly into the picture tube lens while the set is on. First look at the RED CRT. Observe the scan lines in the picture. These same lines should also be present in the green and blue picture tubes.
After looking at the RED CRT for comparison, look into the GREEN or BLUE CRTs. If it is contaminated, it will look like there is a layer of film that you have to look thru to see the picture. There may also be swirls and other various contaminates forming. If it is not as clear and sharp as the RED CRT, it is contaminated, and you should change the coolant fluid. IF you wish to tackle this I will supply more information and instructions. This task is medium to hard for non trained people.
Let me know if you wish to get the instructions on changing the fluid.
Jun 09, 2011 | Mitsubishi VS-6047 60" Rear Projection...
Why does the tv look have a red tint all the time
The CRT coolant is needing replacement in the blue and green CRTs which make the red dominate. You can see the coolant is bad by looking in all three lenses you will see that the red is clear and bright where as the blue and green will be hard to see through which makes the colors dim. Replace the coolant should solve the issue. You can get the Phillips CRT coolant kit from which contains the coolant for all three CRTs and the CD with instructions.
Mar 08, 2011 | Philips 50P8341 50" Rear Projection...
60P8341A looks red
replace the coolant in the CRts . The blue and green coolant gets congealed and causes the red to become dominate and the picture will be dull. You can get the Phillipos CRT coolant kit at the following link the Kit contains the instructions on CD
Sep 13, 2009 | Philips 60P8341 60" Rear Projection...
I have the akai model # ptf492s and the white colors are yellow
I'm almost positive the problem is you have fungus in the CRTs. I know this sounds strange, but it's true. Basically there is coolant fluid in the lamps that develops fungus over time and turns yellow. It should be clear. If you take the back off the television, you will see the 3 lenses (red, green, blue) Each of the lens is held on with 3 screws. Remove the adjustable lens and look at each CRT. Shine a flashlight in they should look white. From what I've read, blue develops the problem first, then green. You can replace the fluid. Look up TV coolant replacement online. It's not to difficult, but you cannot get any of the fluid on the circuit boards or it will ruin it. Mine had a lot of fungus in the blue CRT and a little in the green. The picture looks 100% better now. Good Luck.
May 12, 2009 | Akai PT5492S 54" Rear Projection...
Red and blue faded
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc.
Jan 18, 2009 | Philips Magnavox 9P6034C 60" Rear...
White colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Jul 20, 2008 | Akai PT5598HD 55" Rear Projection...
Television has an extreme red tint
fluid comnated in blue crt and maybe in green
Jun 24, 2008 | Philips 43P8341 43" Rear Projection...
Green Picture
I guess it's missing blue. Even if you see the blue crt working it's not enough and focalised. replace the coolant in it and also check if you have some coolant leak on the crt pcb.
Apr 10, 2007 | Samsung HCN436W 43" Rear Projection...
Replace the green projection gun
I have almost the same problem, but it was with the blue CRT tube. The coolant leaked onto the underlying PCB and caused short-circuits and sparking or arking. I purchased an exact replacement PCB for the CRT, but I suspected most of its coolant had gone, so I need to re-fill the coolant for the blue CRT to stay cool.
Dec 01, 2006 | RCA Scenium HD65W20 65" Rear Projection...
Akai PT5492S 54" Rear Projection Television Logo
188 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
